1/4 mile calculator
Discussion in 'Drag Racing' started by newtoford, Sep 24, 2007.
  1. newtoford
    newtoford Member
    New Castle Delaware
  2. stmanser
    Davenport, Iowa
    "The quarter mile acceleration time of a car that weighs 2880 pounds and has 220 horsepower is 13.728 seconds. The speed is 99.3040749999929 mph. "
    it could be close, since i never had real good traction and wasnt able to truly test it
    my actual time was 14.220 at 96.95mph
  3. MaverickConnect
    MaverickConnect The Maverick Connection
    Parkersburg, WV
    1971 Grabber, & 1971 SuperGrabber
    I have one of the older versions of Desktop Dyno and to be the most accurate, it wants a .Cd(?) (coefficient of drag) number. I checked all my road tests of Mavericks from back in the 70's and apparantly that was not a common piece of data to publish back then. I have used Mustang and Camaro .Cd numbers which I'm sure are similar, but I wondered if anyone has ever had their .Cd measured or they have an article or piece of factory literature that included it. It would be interesting to know.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    This thing want GROSS, NET or REAR WHEEL HP?
  5. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    16 seconds at 86 mph!
    Woot I'm a regular Bandit!
  6. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    It looks to me to be wheel HP and its pretty darn close for me. MPH may be off by 1 for some and ET could be off a tenth. But not bad, I also did by buddys 2wd Dodge diesel @ 5800lbs 11.90@118= almost 700hp. Were thinking more like 650-670. But that calculator may not be able to compute having over 1100ftlbs of torque in a run.
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    very close for me
    290hp rear wheels
    12.62
    108mph
    2950lbs
    close enough to my real numbers....
  8. Mavman72
    My car ran 12.20s' at 110 mph with 3:30 gears and 320 hp out of a 306 with a 600 cfm carb and the wimpy 303 three speed.1.64 60 foot times. The calculator said it should run 11s' 11.70 something. I ran it on slicks once, it ran 11.92 at 111 something and ripped the shock mount off the floor pan.That was 20 years ago at LACR.Soo yeah it seems to be fairly accurate.
  9. mavmanerick
    royal city, washington
    The quarter mile acceleration time of a car that weighs 100 pounds and has 500 horsepower is 3.4070 seconds.
    The speed is 400.13999999996 mph.
    im doing good!:D
  10. Mavaholic
    My car has been dyno'ed at 303 rwhp. Considering best case scenario with 15% loss through drive train, (manual) That would make it around 356 flywheel. I had it weighed on a certified CAT scale with me and a full tank of gas. That came in at 3240. Plugging in the numbers gives me a 12.16 @ 112mph. Thats definitely where my goal was when I built this car. However, with major traction problems, I have yet to cut better than a 2 second 60ft time and it spins tires in all 4 gears. Best I have run is a 12.98 @108. If I cared to address the traction problems, I think I could make it to those numbers.
  11. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    DEFINITELY!
    without a doubt one of the fastest "true street" cars I have ever seen......traction is the only issue with the sprint....cause its got the power (y)
    and its got a gear banging freak that will get too it!!!!
  12. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    The quarter mile acceleration time of a car that weighs 3500 pounds and has 530 horsepower is 10.928 seconds.
    The speed is 124.734034285704 mph.
    My goal.I know the weight might be a little much but i have no clue what it weighs...
  13. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I think it is guesstimating BS. I could put my stock 2.79 rearend in Dennis' Sprint, (I'd have to drive it or he would tear the rear end out-8 incher) and it probably would have a hard time mustering a 14 sec. time.
  14. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    So is there a formula that you can plug in with 1/8 mile times that estimates 1/4 mile time?
    Dan
  15. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    1/8 mile e.t. /.64
