1 More sport mirror ?
Discussion in 'Technical' started by ADC_72Maverick, Sep 23, 2003.
  1. ADC_72Maverick
    ADC_72Maverick Member
    Albuquerque
    Maverick
    My passenger side sport mirror cable is a lot longer than my drivers side. How do you mount this, ie where do you run it to? and where do you run it through to get there? Thanks.:bananaman gotta have the banana man!
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Hmmm....
    ...I don't have a remote operated side mirror for my
    passenger side mirror on the Comet GT. IF you do not
    have a car that came with that sport mirror, I'm guessing
    you don't, then you probably have not got a hole at the
    mirror mounting spot from the factory to run the cable
    through.
    IF you do, the one on my old Mustang II was mounted
    beside the radio. Similar sport mirrors but I do believe that they are different.
    If you do have a hole for the cable, I am still guessing that
    it is intended to be mounted near the radio so that the driver
    could reach it.
    Unless I am wrong, and I have never seen one, these cars did not come with passenger side remote adjustments.
    Which means you have sport mirrors probably from some other Ford/Mercury vehicle.
    I wish you luck.
    Seth
  3. Craig Selvey
    Mavericks never had a remote passenger side mirror. It is off of something else.
  4. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    It's likely a Mustang II mirror. Like was said, it mounts on the dash next to the radio. Craig is right about the Mav mirrors and I don't recall any other mid-size or compacts that had remote passenger mirrors either, other than the Mustang II, as far back as the sport mirrors went back to the late '60s.
  5. Jean Doll
    Palmerton, PA
    I may be mistaken here, but I kind of remember my Mothers Mercury Monach had a remote passenger side sport mirror. I remember a toggle switch mounted near the radio that I could swear was for the mirror. It's been a long time and I didn't drive the car much, so I could wrong about this. Didn't the more expensive Fords and Mercurys have remote pass. mirrors? I'm thinking like the LTD's and the Marquis.
  6. Earl Branham
    Lugoff, SC
    Just a related question...my passenger side sport mirror is loose and the glass moves when I hit bumps. How do you tighten this thing up. I took it off, but couldn't see how it is done. Thanks in advance,
    Earl
  7. Jean Doll
    Palmerton, PA
    If the glass is bouncing around then the pivet ball is worn out. I know of no way to tighten them up other than replacing the mirror. Mine used to bouce all over the place and I could never thighten it up. Then one day I drove over some railroad tracks and the whole thing fell out. You don't need to replace the mirror shell, just the insides of it.
  8. Earl Branham
    Lugoff, SC
    Jean; thanks so much. I'll see if I can find one at the junk yard.
    Earl
  9. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    yes granadas and monarchs had them too, they were mounted under the dash just above the tranny tunnel, some granadas and monarchs have all the bells and whistles you could think of..
  10. bmcdaniel
    bmcdaniel Senile Member
    My Dad's Bobcat (same as Pinto) station wagon had a remote passenger mirror. Talk about luxury!
  11. 71gold
    earl, my mirrow on my grabber was loose and the glass was busted. mustang central said a replacement was $100 bucks. there were two screws holding the glass in. i took it out and went to riverside glass in macon,ga. and they cut a new piece and glued it in. i put it on and as good as new. it cost $15 bucks. they also got me a new windowsheild for $160 bucks. hope this helps...frank...
  12. ADC_72Maverick
    Albuquerque
    Maverick
    Hmm somebody lied on Ebay. Punk, they advertised the mirrors as Maverick sport mirror and look just like my bros, but one has a remote adjustment. oh well. Thanks everybody.
    :bananaman
  13. Earl Branham
    Lugoff, SC
    Frank; the glass on my mirror is good, it is just that it is loose, and moves around when I hit a bump. I guess I need to find another mirror, even if it is not perfect, and get the insides out of it to go into my shell, since it is in very good shape. Will keep on looking, and let you know. BTW, thanks for the info on the glass place. I need to get the gasket sealed up..again..by someone that can pump seal it. Thanks again,
    Earl
  14. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    hmm, i too have a remote sport mirror that i removed from a maverick in a junk yard. I wonder what possessed someone to put it on there?
  15. Mavaholic
    The drivers side were remote adjustable. Its the passenger side that was not.
