200ci clicking
Discussion in 'Technical' started by Andyj, Oct 10, 2013.
  1. Andyj
    Andyj Member
    Bandon, Or
    Maverick
    For those of you who also viewed my previous thread about my 200ci I hosed down, yes, its still not starting. :/ It used to start and idle very very very badly then die in a burst of backfire but now it wont even turn over. Im getting the notorious "click" right as I turn the key. I tried re-spacing the points and even the voltage regulator for the points (currently forgot its name) and still no luck. Now with 2 issues to tackle you guys have any ideas? And are both the awful idle/run and the "click" related? Your guyses expertise would be much appreciated :)!!
  2. 71gold
    click sounds like...battery low...or loose cable...:yup:
  3. Andyj
    Andyj Member
    Bandon, Or
    Maverick
    Battery is fine I tested it by starting one of my other cars. :/ if it is a loose connection where are the first palces I should check? The dome light and radio work.
  4. Krazy Comet
    If you have a chattering solenoid then either the battery is weak or maybe have a cable problem... If it just clicks once, then the battery is likely OK and there is a problem with the cable from solenoid to the starter, if that's OK you could have a bad starter...
    BTW
    .I've seen very weak batteries that would operate a newer permanent magnet starter, but wouldn't begin to operate a old field coil starter that were orig on our cars....
  5. Andyj
    Andyj Member
    Bandon, Or
    Maverick
    Thanks Tom :)! Ill definitely check out the solenoid connections!
  6. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    try to start it if the cable from the battery is hot its probably the starter
  7. 71gold
    have the battery...load tested...:yup: (any auto parts store)
  8. Andyj
    Andyj Member
    Bandon, Or
    Maverick
    Ill check if the battery cables heat up as soon as I can. Do you think the rough idle (when I do figure out the electrical issue) could be because I somehow got water into the fuel lines while I was spraying down the engine? Or is that pretty slim of a chance.
  9. 71gold
    :hmmm:...no chance...
  10. Andyj
    Andyj Member
    Bandon, Or
    Maverick
    Thanks Frank :) well you guys have me feeling pretty good about the possible problems and it appears its not something too serious :)
