21 yea old w/a 30 yr old car
Discussion in 'New Members Forum' started by Loralyn, Dec 20, 2006.
  1. Loralyn
    Loralyn New Member
    OKC, OK
    1976 Maverick
    Hi, my name's Loralyn and I'm a 21 year old girl who just bought a 30 year old car. The Mav and I have been through a lot together in the past couple of months, but I'm about ready to call it quits and break up with it. It's a v8 302 with a/c. I'm having problems with the car over heating. So far, I've...
    -flushed the radiator more times than I can count
    -put a new thermostat it (I knew it couldn't be THAT easy to fix the problem)
    -put a new (BRAND new) radiator on
    -checked the lines, they're all great
    -got two new radiator caps (one of each kind)
    -rigged up an overflow tank
    -my next move is to put a new water pump in- that's this weekend.
    It all started when the original radiator cracked. I replaced it with a brand new radiator, which quickly started overheating. The radiator fluid would overflow and would spill out more than HALF of the amount in the radiator, which is what I figured was causing this overheating. I then bought a new cap from oreilly's (just the push down and turn kind). This cap didn't have the right fit b/c it was still overflowing and then over heating. I bought a cap with the red lever that closes the system a little tighter and added a home-made overflow tank. This fixed the problem for a little while.
    As soon as that was done, the heater hose decided to crack, so I trimmed that down and tightened it back up; everything was fine.
    All of the sudden, out of no where, it started to overheat again this week. I know that the engine got pretty hot b/c it started making that god aweful noise that engines make when they're trying not to explode. (really loud, higher pitched squalling noise) I assume that this was due to my water pump going out b/c that's just about the last of the new part replacement options. I have that new water pump sitting in my garage, my weekend is entirely dedicated to replacing that. Until then, I'm just filling it up with water constantly and driving it as normal. (this is my only source of transportation).
    With this car, it's been one thing after another. It's only got 58K original miles on it, so it really shouldn't be acting up like this.
    Are there any secrets anyone out there knows about getting this damn car to behave? And also, does anyone know exactly what the overflow situation is on this car? There's an overflow hose that comes from the top of the radiator and runs down along the side, but that doesn't do too much for keeping the radiator full. When I put that second cap with the lever on and added an overflow jug, it seemed to make a WORLD of difference.
    Also, this past week, a tacking noise started in the engine. I figured that I might've just gotten all of the gunk lose in the engine and oil, so I changed the oil tonight. Ever since I did that, I've noticed a blueish/whiteish smoke coming from teh exhaust. Other than burning oil, what could this mean? I know that this could be a cracked head gasket, radiator fluid in the gaskets, or the seals and rings in the engine have finally given way which would mean an engine rebuild.
    I need help! Please!
  2. 71gold
    :wave: :Welcome: :Handshake ,
    you are at the right place for any help you may need. (y) .
    the overheating problem can be tricky. it could be as simple as putting the right pressure radiator cap on, to a head gasket being blown.
    you may be on to something with the water pump.
    let's get the overheating fixed first and then we will address the smoke.:tiphat:
    you may have toasted your valve seals.:yup:
    ...frank...:bouncy:
  3. 19BlacK77
    19BlacK77 Member
    :Welcome: to the site!
  4. don graham
    welcome to the board.:Welcome:
  5. CHOCO3
    CHOCO3 Member
    HOUSTON,TEXAS
    1977 COMET
    Mine is having an electrical problem and i cannot find it....
  6. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome aboard
  7. Jamie Miles
    :Welcome:
    Sometimes you just gotta get the bugs worked out of these old cars. Good luck.
  8. Mercurycruizers
    Venetia, PA
    :Welcome: to the board. Sounds like you might have the overheating problem solved, after replacing the water pump. Unless it's a blown head gasket. Keep at it. These cars need tender loving care. Pics, we love pics....
  9. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    :Welcome: to the board:wave:
  10. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    1972 Maverick Grabber
    Welcome and good luck
  11. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    :Welcome:
    Do you have any pics ofthe car? We Love pics!!!:evilsmile
  12. claridger
    claridger Member
    San Antonio, Tx
    1972 Comet GT
    :Welcome: If you have a fan clutch, I don't know if these cars came equipped with one or not, this will cause the car to overheat and is easily overlooked. Even if the clutch still has resistance to being turned by hand (with the engine turned off, please), they can be bad.
    Hope that this helps.
  13. Jamie Miles
    I've never seen a Maverick with a fan clutch, don't think they ever came with them.
  14. Wilmer
    Wilmer New Member
    Jasper Ar 72641
    When the car is running you might want to go back and smell the exhast. If it smells like antifreeze you can bet on headgaskets at the least and more likely cracked heads from overheating. A bad water pump will certainly cause overheating. I've had the propellers come loose and spin or even break. I just bought the same car and plan on driving it 1000 miles home. Good luck to both of us. Will
  15. robbinsdrj
    robbinsdrj Member
    panama city
    1971 comet
    you mite want to make sure the raditor is a three core it mite help
