250ci for a 302ci ????
Discussion in 'Technical' started by revatoons, Nov 26, 2008.
  1. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    Hello I am thinking to change my 6L 250ci for a 302 v8 but I dont know if I need strengthen or change anything in the steering and front suspension!
  2. newtoford
    newtoford Member
    New Castle Delaware
    from the factory the only diffrence between a v8 maverick and a 6cyl is a slightly larger sway bar and 5 lug wheels instead of 4 lug on the older models
    but assuming all your suspension is original then its well over 30 years old and probably a little tired. it may be time to do springs, bushings, ball joints, tie rods, ect anyway
  3. don graham
    Also there's a belly bar under the engine area in a v8. Lot of discussion wether it's really needed or not. Same thing with the tranny crossmember if you are going to dual exhaust. This has been discussed lots of times. Use the search function and you should find all the info you'll need.:)
  4. newtoford
    newtoford Member
    New Castle Delaware
    ya, i think this thread, by one author or another, pops up atleast once a week lol :)
  5. chasiscorto
    chasiscorto Member
    Caracas, Venezuela
    4 door, 6cyl 250 c.i. 1976 Maverick
    Hola pana, en qué parte de Venezuela estás?
    Puedes conservar muchas piezas, el tren delantero lo debes hacer o al menos revisar, los espirales del 250 sirven para el 302 siempre que no estén vencidos, hay una barra que va entre las bases de las mesetas de abajo que nunca conseguí y la base de la caja debes cambiarla si quieres que el escape del lado del chofer (si usas doble escape) no quede más abajo que el otro. El radiador debe ser de 3 canales, casi todos los máverick que trajeron 250 lo tienen. El carter del 302 no debe chocar con las barras de la dirección, creo que es de los modelos viejos (mustang, fairlane, LTD, etc)
  6. baddad457
    :DAlways good to read this stuff and brush up on my spanish:thumbs2:
  7. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    :hmmm::hmmm:
  8. Jamie Miles
    The translator on Google had this to say:
    Hello corduroy, in which part of Venezuela are you?
    You can keep many pieces, the front axle what to do or at least revise, the spirals 250 useless for the 302 provided they are not defeated, there is a bar that goes between the bases of the plateau below that and never got the basis of the box should change it if you want to escape on the side of the driver (if you use the dual exhaust) is not lower than the other. The radiator must be 3 channels, almost all the maverick who brought 250 do. The carter of 302 should not hit the bars of the leadership, I believe it is of the old models (mustang, Fairlane, LTD, etc.)
  9. chasiscorto
    chasiscorto Member
    Caracas, Venezuela
    In english now...
    Hello my friend (corduroy? hehehehe), where in Venezuela are you?
    You can keep using many pieces, the front end haves to be rebuilt (overhauled) or at least deeply checked, the front springs you use with the 250 can be used with the 302 if there are not tired already, there is a crossmember that is located between the lower control arms mountings that i never found here and the tranny crossmember must be changed if you want the driver's side exhaust pipe (if you go with dual exhaust) don't sit lower than the passenger's side one. the radiator must be three tubes wide, almost any maverick here with a 250 l6 engine came with that ones. The 302 carter must not interfere with the steering linkage, i think that old models ones won't do (mustang, fairlane, LTD, etc).
    See? I'm better than google's translator, hehehehehe :biglaugh:
    Pana here is a way to say friend, like saying dude or some... (corduroy is a type of fabric here is called pana too...) -This was a language moment sponsored by: CHASISCORTO (short chasis). hehehehehe
  10. baddad457
    (y) Yea Google didn't make much sense either. I got the meaning of most of it translating it in my head, not too bad considering I last took espanol in the 6th grade (about 40 years ago:biglaugh:)
  11. chasiscorto
    chasiscorto Member
    Caracas, Venezuela
    Hehehehehehe, good memory!!!
