3.55 Gears
Discussion in 'Technical' started by Elephant, Feb 19, 2014.
  1. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    I'm searching for some 3.55 gears for my 8" rear end. The 3.00 gears just aren't cutting it! I've done a good bit of work to motors and whatnot but never really messed with gears...what am I looking for to ensure a match? What kind of a job is swapping gears? Thanks!
  2. Dave B
    Depending on your knowledge, it's a tricky job to do. Much easier to buy a rebuild kit, and a set of gears, and take it to a shop that does that stuff.
  3. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Kind of what I thought. As far as compatibility, what am I looking for?
  4. baddad457
    You're looking for a gear set for an 8" rear. As far as it being complicated to install them, it's pretty simple, you have to pay close attention to setting the gear pattern and pinion depth. I've heard of many shops screwing this up so it's a crap shoot. I would ask around and get feedback from those who have had this done by someone else in order to minimize the chances of having a negative outcome. If you are looking for a reliable guy to do this, there's one over here west of you between Baton Rouge and Opelousas.
  5. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Thanks for the info sir, that wouldn't be too bad of a drive, especially if they can do it on the car that same day!
  6. Krazy Comet
    If you pull the carrier(hogs head) and take it to them you'll save $150-$200...
  7. 71gold
    agree...and wanting it in one day, just make an appointment to do it that way.
    gear set...bearing kit...:thumbs2:
  8. mojo
    Most shops here "that I wud trust", will not install a set u supply.
  9. Dave B
    That's weird, around here I know two shops that would do it tomorrow, no problem. One guy was a Ford Factory drag racer from the 60's.
  10. baddad457
    The guy I'm recommending has no problem installing parts supplied by the customer. And he does top notch work. He's not the uptight type, very laid back kind of guy. He kin spel too.
  11. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Sweet. And shows how much I know, I figured they could be replaced ON the vehicle. Heh. Will plan to remove the chunk and being it in. THAT I can do
  12. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I just found a whole third member at a salvage yard with 3.55's in it, refreshed it and installed it works great. Cost me $75 and it turned out to be a Trac-Loc. I found it in a Pinto wagon.
  13. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Lucky dog! Let me know if you come across another one of those!
  14. baddad457
    Better run down and buy lottery tickets too. It's your lucky day
  15. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    When whoever gets ready to install it,if they don`t show up w/ a dial indicater on a stand,& some blueing to put on the gears,I would be concerned.Not a hard job,but you don`t want to get stuck w/ roaring gears or out right failure if not done correctly.Just my 2 cents.Also the hogshead needs to be mounted in a vise.
