3:55 Pos Mustang 2 Rear Gear
Discussion in 'Technical' started by Stews72s, Jan 13, 2008.
  1. Stews72s
    Stews72s Member
    N.C.
    1972 sprint maverick
    DOES THIS 8 INCH MUSTANG 2 CHUNK WORK IN THESE MAVS,GOOD 1/8 MILE GEAR OR WHAT
    (y)STEW
  2. newtoford
    newtoford Member
    New Castle Delaware
    yea it'll work
    alot of mustang II's and pintos are trac-locs too, mostly the stick shift cars.
    your car probably has a 2.79 or 3.00 stock
  3. Stews72s
    Stews72s Member
    N.C.
    POS ,TRACK LOCK,THATS WHAT I MEAN,FORD:thumbs2:
    STEW (y)
  4. Stews72s
    Stews72s Member
    N.C.
    MY CAR IS A 3:00
  5. newtoford
    newtoford Member
    New Castle Delaware
    i know i wouldnt mind having a 3:55, ive got 2:79s now...
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Pinto, Bobcat, and M2 8" rears have decent gears.
    The V8 M2s have limited slip standard, however they only have 3.00 gears.
    The I4 and V6 M2, BC, and Pintos are harder to find with LS, but the gears are 3.40s and 3.55s.
    I have heard that V6 Bobcats are the best place for 3.40 LS.:huh:
    Pintos didn't have LS as an option, but 3.55 gears were common.
    To get an LS, you gotta go BC or M2.
    The tag on the rear will read something like:
    3.___55 for an open diff 3.55, or 3.__L__55 for a limited slip 3.55.
  7. Stews72s
    Stews72s Member
    N.C.
    i MIGHT COULD HELP YOU OUT:),LET ,ME CHECK
    STEW
  8. don graham
    all 8" rears are interchangeable. 3.55 should be a good street gear. not the best for 1/4 mile or 1/8 mile racing, but a lot better than what you got now.:)
  9. Stews72s
    Stews72s Member
    N.C.
    Inset
    The Ones Im Talking Have Inset Ring Gear Bolts
  10. don graham
    The ones with the inset bolts are usually tral-lok rear ends.:)
  11. Stews72s
    Stews72s Member
    N.C.
    Ok Thanks
    THATS WHAT I THOUGHT:thumbs2:
    STEW
