3 speed collumn automatic
Discussion in 'Technical' started by thedevil, Jun 14, 2007.
  1. thedevil
    thedevil New Member
    belgium
    ford maverick 250 6 -.I
    hi i have a 74 maverick with a 6I 250 cui engine but that is total broken it use oil and it leaks oil now i can buy a engine from a ford mustang 79 v8 302 now i know that i need to change some brackets but my question is now can i uste the transmision and cluth from de 250ci for the 302 ci
    thanks a lot i live in the netherlands so i don not have many options here because i believe there are 2 mavericks here and one in belgium but ther are mexicans ours is coming from america (1991) we just bought him to try to rescue the car
    greetings gust
  2. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    The trans in the 250 i6 is a c-4 automatic. The c-4 bolts up to the 302 however you may need a new flexplate.
    People correct me if I'm wrong because I'm not 100% sure.
  3. 71gold
    ...is the trans. in the '74 mav. a c4?
    ...:bouncy:...
  4. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    I think he said it was a 3sp. on the colum. Not a c-4. Probably will have to change bell housing to matchup.
  5. 20cows
    20cows Member
    West Texas
    74 Maverick
    He said:
    C4's are 3 speed automatics.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    No matter what tranny it is, the 250 bell is same as the 302.
    The flywheel/flexplate will bolt up, but the balance is wrong.
    A clutch or converter will swap when the balance problem is solved.
    If it is a manual tranny, then the clutch linkage will need to be totally changed to the V8 parts.
  7. PaulS
    The transmission will bolt up if:
    you get a new converter and the correct flex plate for the 302.
    That's the good news.....
    The bad news is that the tranny that is connected to the 250 uses fewer clutches than the tranny for a 302 and the second gear servo is smaller. That means that you will probably burn the tranny up very quickly. You can make it last longer if you install (or have installed) a TransGo 40-2 reprogramming kit and a big (30000 lb rating) transmission cooler. The transmission will not take any abuse - so if you are going to hammer it then start out with a good rebuild and update it to the V8 clutch packs and an "H" servo for the second speed band. Then put in the reprogramming kit and the big cooler and it will last 10 years or more. (normal driving, on the street, with proper maintenance)
  8. 71gold
    I used a 250 6 cyl. c4 behind my built up 302 with no problems...(y)
    street/strip...for about 3 yrs. :yup:
    everyday :drive: :burnout: it will be fine... :yup:
    ...a "(30,000 lb rating) transmission cooler." :rofl2: :clap: "now thats funny, i don't care who you are." :yup:
    ...:bouncy:...
  9. ratio411
    ratio411 Member
    Pensacola
    Paul knows his trannys.
  10. 71gold
    ...but we were talking about ...transmissions...:D
    ...:bouncy:...
  11. thedevil
    thedevil New Member
    belgium
    thanks everyone i think i am gonna try it but th problem here is you cant find many spare parts here it not a point of use several items we also have a amc hornet 6 cilinder and that i have changed to a 360ci but that was easy to do because we have a javelin and ald the parts are easely switchtable
    so we wil see the results with the mavie
    THANKS everyone
