302??
Discussion in 'Technical' started by d_chavez, May 31, 2008.
  1. d_chavez
    d_chavez Member
    Las Cruces, NM
    70 Maverick 302 C4
    ive got a 86 302 and i was wondering how i can figure out what it came out of its got a roller cam the oil pan has two humps and if it uses a reverse rotation pump can i still use my timing cover off of a 79 block and just get a reverse pump.....??????
  2. baddad457
    It came from a car application if it's got a dual sump oilpan. You can use either waterpump or timing cover, but these two have to match. Some of the early 80's reverse pumps fit the std rotation cover, but the late 80's reverse pumps fit only the reverse covers. Any timing cover will fit any block. The advantage of the later 80's timing covers is they use locating dowels to fit the timing cover. There are both std and reverse covers with this feature. The Crown Vic/Marquis/Town Car 5.0's used a std rotation cover and pump.
  3. d_chavez
    d_chavez Member
    Las Cruces, NM
    70 Maverick 302 C4
    what about the fly wheel do i have to use a newer one or can i still use my old one?
  4. baddad457
    You need a 50 oz/in flywheel/flexplate. The 79 wheel is 28 oz/in
