302w engine swap
Discussion in 'Drag Racing' started by Maverick9115, Jul 30, 2017.
  1. Maverick9115
    Maverick9115 Member
    Ohio
    70 Maverick
    Started the engine swap process, taking 302w out and swapping in a 351w. We are taking out the shock towers and putting new coil overs, upper A arms and forward struts. We have a stock front end. Anysuggestions and advice would be awesome.
  2. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    With y'all takin out the shock towers it should be fairly straightforward. Just gotta watch hood/carb clearance
    Maverick9115 likes this.
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I'm in the process of putting an aje strut front suspension on my car. In my opinion it's the way to go for room u derived the hood and driveability.
  4. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    In addition to pics of the final installation when you're done, can you take a few pics of how you modified the sheet metal to accept the struts? I'm sure the members would greatly appreciate it. :bouncy:
    MD
  5. Maverick9115
    Maverick9115 Member
    Ohio
    70 Maverick
    Some progress made today! We are only able to work on car once a week! Getting ready to jack it up and take springs out and cut out towers.
    Maverick Dude likes this.
  6. Maverick9115
    Maverick9115 Member
    Ohio
    70 Maverick
    Pulled out all the old wiring what a mess!! Any recommendations on fuse block? Had a old glass bulb fuse block
  7. Maverick9115
    Maverick9115 Member
    Ohio
    70 Maverick
    Shock towers are completely cut out, next step is putting the rest of the roll cage together and foward struts. Any recommendations on upper A arms and coil over setups for a race car?
  8. skeeterc144
    skeeterc144 Member
    Wv
    1970 maverick
    I recommend a ARC touch pad set up..they come with a self contained fuse and relay panel. Very simple to install and have a lifetime warranty. I really like mine
  9. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    I pulled all the old wiring and installed a Painless 16 circuit kit in mine even though I didn't need all those circuits.
  10. Maverick9115
    Maverick9115 Member
    Ohio
    70 Maverick
    My dad and I are in the process of upgrading our race car!! We went with the whole cutting out the towers and creating more engine space!! We still have to find coil overs but have the ride height where we want it!! The plan is to install a 351w stroker engine! This is a budget build but are looking to improve on what we already had!! We used to run 11.50’s with our 302 but the plan is to get to 10.90s!!
    Hotrock likes this.
  11. mcknight77
    mcknight77 Member
    Boise, ID
    Can you give me some details about the 302 you're taking out, how it was built, etc.?
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's funny how people always refer to the 302 as a "Windsor".
  13. mavman
    mavman Member
    Arkansas
    It differentiates the US 302 from the Aussie 302, which used cleveland heads as I remember. Basically a Boss 302 but IIRC, had the smaller 2v style ports with the nice tight 4V closed chambers.
  14. Krazy Comet
    BUT for US 302 Windsors, every one was was cast and built at Cleveland.
    The Windsor plant opened in 1966 and built 289 through '68, then switched to 351 for '69 models. Meanwhile Cleveland was also building 289 and been doing so since it's introduction in mid '63. Till 1970 there was no such thing as a Windsor, the 351 was part of small block family. Because Cleveland built a different 351, a distinction became necessary.
    Crazy Larry likes this.
  15. Maverick9115
    Maverick9115 Member
    Ohio
    70 Maverick
    It’s been a while butt progress is being made.
