351W dipstick provision?
Discussion in 'Technical' started by htr701, Sep 1, 2008.
  1. htr701
    htr701 Mavericker
    Bradenton, Fl
    Well I have what I imagine is a '89 351w. The problem is finding a oil pan with a front sump and it having a dipstick in the pan. All the earlyblocks had the dipstick through the timing cover. How can I get a dipstick in this thing? Is there a front sump 351w pan with dipstick that goes through the pan? What are my options for the timing cover? Thanks:bowdown:
  2. newtoford
    newtoford Member
    New Castle Delaware
    i wish i took a better look at my 351w i got today to give you a good answer. its a stock 73 front sump motor heres the only pic of the front i have. since the 302's of that era had the stick through the timing cover i'd imagine the W's do too. i think the timing covers might even interchange?
    i'll have a percise answer for you tomorrow though when i start cleaning mine up
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Just swap the timing cover it is the same as a 302. You can purchase a stock replacement pan and pickup for under $100.
  4. htr701
    htr701 Mavericker
    Bradenton, Fl
    awesome, thanks! I'll just get the timing cover...but I didn't think a 302 and 351w cover was the same.
  5. newtoford
    newtoford Member
    New Castle Delaware
    if your working with a rear sump 351 your going to need to plug up the stock dip stick hole in the block
  6. htr701
    htr701 Mavericker
    Bradenton, Fl
    My 351w had the dipstick in the pan. Is there a way to route the dipstick through the block for a front sump by any chance? I looked for a spot, but didn't see a thing.
  7. htr701
    htr701 Mavericker
    Bradenton, Fl
    Also, by swapping the timing cover, will I need anything else new, such as a waterpump??
  8. maverick1970
    Missouri
    Just make sure the cover matches the rotation of your water pump. I bought a new cover from Keith Craft and it came with the plug for the block. They are on ebay as well.
  9. newtoford
    newtoford Member
    New Castle Delaware
    ya, my 351w's dip stick definatly goes into the timing cover...
