4 speed toploader Speedo cable
Discussion in 'Transmissions' started by Ford Freak, Jun 21, 2018.
  1. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    F0BA5C59-EA8C-4043-9EF8-FE748641EFFD.jpeg Hey guys. Just curious if anyone has any info on the speedometer cable that will work on a 4 speed toploader
    I’m using my donor trans out of my Mexican Mav parts car
    Where I can buy one or will my automatic one in the 70 work? I read in the interchange that the Auto will work but I just wana confirm
  2. yellow75
    Tillamook Oregon
    Your automatic one will fit if it is long enough and it should be, you might have to change the gear on it to have the speedo correct but that is easy and available from just about every vendor they go by colors and teeth count and you can just pull it out after car is running and change it without loosing any gear oil
  3. tody
    tody Member
    cologne, germany
    c4 cable might be too short, toploader is going in from the opposite side. i used a mustang cable.
    Ford Freak and Krazy Comet like this.
  4. Shorty
    Shorty Member
    Lafayette, In
    My C4 cable worked fine when I converted to the 4-speed.
    Bruce
    Ford Freak likes this.
  5. Krazy Comet
    Very likely, toploader speedo cables have always been 8-10" longer than auto cables.
  6. rthomas771
    Top loader 4-speed takes a left hand gear...C4 and 3-speed trans take a right hand gear
  7. Shorty
    Shorty Member
    Lafayette, In
    Interesting... I remember the speedometer working in the right direction. Pretty sure the accuracy was off because we installed a 4.11:1 geared 9" differential at the same time.
    Bruce
  8. Ford Freak
    Thank you , where did you order it from?
  9. Ford Freak
    Thank you very much guys.
  10. Ford Freak
  11. Ford Freak
    As for the speedo gear , any tips ?
  12. rthomas771
    The cut of the gear doesn't determine which direction the speedometer cable spins. The direction of the engine rotation does.
  13. Krazy Comet
    Well that's not quite correct, the rotation of trans output shaft determines which way the speedo reads. Granted if you can get your engine started in reverse rotation, the speedo will read backwards. Good way to remove milage as well.;)
    If no one else has it David Kee of Toploader fame has the correct angle gear.
    http://4speedtoploaders.com/store/speedometergears.html
  14. rthomas771
    My bad. I always look forward to things...not backwards. :happy:
  15. baddad457
    Well your wrong here. Rotation from moving the cable from the driver's side to the passenger side reverses the direction the cable turns. Ford made left and right cable gears to change this along with different shaft gears that had opposite canted teeth.(for the manual transmissions ) And it gets damned confusing on what gears work together. Been there, done that. The speeedo in my Comet still doesn't work because I picked the wrong combination of gears in my Toploader. Then my cable got burnt on my headers so I just gave up and use the tach to estimate my speed.
