4 speed
Discussion in 'General Maverick/Comet' started by Lucifer, Jul 6, 2021.
  1. Lucifer
    Lucifer Member
    Canada
    1972 comet
    I just ordered the master clutch set up from modern drive line for a 72 comet i have a close ratio toploader with a 69 mustang tailshaft from dan willams and a competition plus hurst shifter, ram internal hydraulic release bearing thingy ,Mc Leod 17.5 fly wheel with different weights for different 5 liter years and street pro clutch/pressure plate being attached to a 347 stroker blueprint engine, Holley sniper fuel injected carb( looks so cool), on a old school 289 torquer intake . 9 inch ford axel slightly narrow still on springs off set for MT ET Street tires tucked into fender wells It has been quite a journey I want to thank Bruce at modern drive line for his expert advice , Dan Willams just for the good conversation and staying old school and Brent at gears to go in Vancouver for your guidance ...Brent if you see this, I think we need the twin disc clutch cause i just ordered a nitrous kit.
    When i can i will post pics.
    I do need to figure out a clutch pedal so any help there i do have one from MDL for a 69 mustang it may work out.
  2. Lucifer
    Lucifer Member
    Canada
    1972 comet
    Blueprint engine tec. Says no nitrous possible good advice
  3. bmcdaniel
    Must be running hyper pistons.
