4 To 5 Lug
Discussion in 'Parts Interchange' started by JLUDE96, Aug 27, 2007.
  1. JLUDE96
    JLUDE96 Member
    BALTIMORE
    1970 MAVERICK
    when i purchaced my 70 mav, the original owner had converted to 5 lug all the way around. what was the common car to get the 5 lug from. I may be able to get a set of front and rear disc brake setup (aftermarket) and they what to know which year and make. I want to tell them the correct info so im not stuck with something that might not work. I read in other posts that the mav. spinles changed slightly from year to year. Any help would be appreciated.
  2. bmcdaniel
    All drum brake Mavericks used the same spindles regardless if they were 4-lug or 5-lug. Same part number as a 70 Mustang drum brake spindle. The only change in Mav spindles was when they went to disc brakes.
  3. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    What he said...(y)
