5.0 Flexplate
Discussion in 'Technical' started by d_chavez, Dec 12, 2008.
  1. d_chavez
    d_chavez Member
    Las Cruces, NM
    70 Maverick 302 C4
    Ive got a 90 5.0 HO and i was wondering if i could use the stock flex plate with a C-4. someone told me that the c4's converters studs on the c4 dont match up with the holes on the 5.0's flexplate.
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    The stock plate is 164 tooth and the plate you need is a 157. But, Be sure to get a 50.oz balance.
  3. scooper77515
    $45 off of ebay. SFI approved.
  4. baddad457
    Depends on what C-4 bell you've got. C-4's came with three sizes in flexplates: 147T 157T and 164T. Only the 164T wheels came in both balance weights. There are aftermarket 157T-50 oz/in flexplates.
  5. 71gold
    flexplate has to match...engine balance and type of transmission...
    ...:Handshake...
  6. greasemonkey
    Sedalia,MO
    How many of those bells came in a maverick, and which ones will actually fit the mav?
  7. mean_maverick
    157T came in Mavericks.
    and as mentioned, you must get a flexplate/flywheel that matches your engine's balance and trans/bellhousing.... in your case you need a 157T 50 oz. imbalance, and like Scooper said, they're on eBay for $45
  8. greasemonkey
    Sedalia,MO
    Thats what i thought. None of the others came in mavs. And i know about the balance deal Thats why i said it needed a 50oz balance.
  9. baddad457
    147T was a Mustang II piece. 157T was what was mostly used in small to midsize cars. 164T was mostly used in larger cars and trucks. The emphasis here is "mostly". At this point in time, what's there now in any vehicle can be a crap shoot.
  10. 71gold
    this is on my...'91 5.0...roller motor..
    W/AOD
    [​IMG] FMS-M-6375-G302 Ford Racing Flexplates
    Flexplate, 164-Tooth, External Engine Balance, 28 oz., 2-Piece Rear Main Seal, Ford, 289/ 302/ 351W, C-4/ AOD
    Monday$63.95
