5.0 L High Output
Discussion in 'General Maverick/Comet' started by Canuck, Sep 11, 2014.
  1. Canuck
    Canuck Member
    Calgary, Alberta Canada
    1973 Comet
    I am removing a 5.0 HO motor from a 1989 Lincoln Mark VII. What is important to keep from the engine if I am planning on running a carburetor instead of fuel injection?
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Keep the fuel injection manifold , injectors , fuel rails , and the computer and wiring harness if possible along with the IAC and whatever else is connected the the injection setup . If YOU don't use it .. there is always a market for those
    components .
    Cometized
    (Chip)
  3. Canuck
    Canuck Member
    1973 Comet
    Thanks, is there anything I need to grab to make the switch to carburetor work?
  4. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Depending on what transmission you are going to run you may need a 157 tooth flexplate/flywheel. And you'll also need to make sure your distributor has a steel gear.
  5. Canuck
    Canuck Member
    1973 Comet
    Thanks, I will run an AOD transmission from a 92 Grand Marquis. Will the distributor on it now (factory) possibly not have a steel gear?
  6. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    yes it will have a steel gear.
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Regarding my last post on saving the fuel injection parts.. I didn't mention the throttle body , breather , and anything else that connects to the fuel injection setup. Save them.. someone will want them eventually.
    Cometized
    (Chip)
  8. Krazy Comet
    The LSC wiring harness is approx 15ft long and has the ABS and and air suspension intertwined into it, useless except for another LSC... It's nothing like the Mustang or Fox T-Birds...
    You'll need the front sump oil pan and pickup if you don't already have it, also front cover and fuel pump eccentric if you are planning on using mechanical fuel pump... The front sump also requires a front dipstick and tube...
  9. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Is the motor out of an automatic or a manual?
  10. Krazy Comet
    There were no manual LSC...
  11. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    OK wasnt sure. I had an issue with mine cause I didn't know pilot bearings existed. Wanted to make sure no one else went thru that hassle :)
  12. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
  13. SamsDad
    SamsDad Member
    Little Rock, Ar
    Also make sure to KEEP all the serpentine stuff, that is a one of the best things we have done was going with the serpentine
  14. Tylermav94
    Tylermav94 Member
    Drumhellar Alberta
    1972 Ford Maverick
    I am coming to Calgary so I can see you and your car sometime! Lol I need more maverick buddies there's like nothing in alberta
