5 lug drum swap
Discussion in 'Technical' started by MATTBLACK, Nov 4, 2010.
  1. MATTBLACK
    MATTBLACK Member
    Abbotsford B.C. Canada
    I have a 70 maverick. Grandma stock. 200 / 6 , 4 lug. I'm building it into a drag car. I would like to swap it to 5 lug drums due to the zero drag that I can dial into the shoes for the track. Will the 5 lug drum hubs swap onto the existing spindles, or do I have to grab the 5 lug drum spindles as well?
  2. Acornridgeman
    Wisconsin
    I know the 4 lug and 5 lug drums take the same bearing and seal. Somebody that has done the swap can tell you if there is a difference but I know that is the same.
  3. brainsboy
    brainsboy Member
    Tampa
    All drum spindles are the same, however keep in mind you will also need to change the backing plates, brakes, and wheel cylinders, because the 4 lug setup uses a 9" brake while 5 lugs use a larger 10" brake system.
  4. Acornridgeman
    Wisconsin
    Oh yes, forgot that one - brakes are larger with the 5 lug ............. :thumbs2:
  5. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    You need to change out the system. I have done this before. You also need to change the rear end.
  6. MATTBLACK
    MATTBLACK Member
    I already have a 5 lug 8" out of a later maverick so that's ok. just lookin for the front end.... I like the self energizing aspect and zero drag of the drums....brake fade isn't really a concern, in drag racing you really only have to stop once....:)
  7. predfan2001
    I just did the swap and used 70 Mustang frt brake parts.
  8. bmcdaniel
    Yep, 1970 is the only Mustang that shares the Maverick drum spindles. All Maverick drum spindles are the same, 6 cylinder and V8.
