57 ford 9 inch question
Discussion in 'Parts Interchange' started by Jamie Miles, Apr 27, 2009.
  1. Jamie Miles
    I know where there is a 9 inch under a 57 Ranchero. This thing was set up for drag racing back in the late 60's, and had a lot suspension stuff done at that point, but still has rear leaf springs (though I don't even know if they're still in the factory location or not). I was looking at it yesterday, and noticed that the center of the rear where the differential is, is a few inches off center to the drivers side of the vehicle. I couldn't say exactly how far off center it is without measuring, but it's clearly noticeable when you look at it. Is this normal for a '57 9 inch? Or has someone swapped some other 9 inch under there?
  2. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Jamie if you mean that the axle tube on one side is longer than the other...I think its been changed .
    My car has a 57 type big bearing 9" and it looks centered.
    So does my "spare" one.
  3. rthomas771
    The right tube is a little longer than the left tube
  4. Jamie Miles
    Yep, that's exactly what it looks like. Thanks!
  5. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Jamie,
    Are going to tell where is? :rofl2:
    What size are the brake drums? I think I have one. It has junkyard marking of 58.
    Rick
  6. Jamie Miles
    It's under this old heap. Have no idea about the brake drums. I'll take a look this weekend.
  7. SeanC
    SeanC Member
    Vegreville, alberta,Canada
    1972 comet GT
    Hey there. Just wondering where you guys that are using these 57 diff's are finding drums for them. I haven't had any luck finding drums for mine and I'm running out of time to race day.
  8. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    You should be able to go to any parts store and get them . I looked up a set shoes for a 58 ford edsel and a 54 chevy pick up a while back.
  9. lastchance
    lastchance Member
    Hingham , Massachusetts
    Kanter Auto Parts has them. 499.00 EACH
  10. Jamie Miles
    Holy crap. :16suspect You could probably swap discs onto it cheaper then that.
  11. Joe Dirt
    that is sweet!
  12. lastchance
    lastchance Member
    Looks like I better read my posts better. That should be $99.00.
  13. Jamie Miles
    Yea, it's really cool. It's to bad it's such a rust bucket, or otherwise I would get it going again. Has a spot where the frame is rusted through.
  14. Joe Dirt
    That sucks how bads the body
  15. Jamie Miles
    Pretty bad. Everything behind the doors is wrapped in fiberglass for some reason. Over the years the fiberglass has separated and water has collected behind it. I don't know that there is any rust though, but all the sheet metal that I can see back there has huge pits in it. Would probably look like swiss cheese if you sand blasted it. The whole thing is probably restoreable, but it would take a lot of work.
