67/68 mustang disc brake spindles ?
Discussion in 'Technical' started by MilkshakeMan63, Mar 13, 2017.
  1. MilkshakeMan63
    MilkshakeMan63 Member
    Regina
    1975 Comet, 1971 Comet GT
    i have the chance to buy a set of 67/68 mustang spindles with disc brakes on them for a good price I'm just am not 100% sure these will work and so I'm asking you guys. Thanks.
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    1967 Ford Mustang spindles are the same drum to disc. They used Kelsey Hayes 4 piston calipers. They were used on drum brake Mustang/Cougar and mid size B/C body cars like Fairlane 1966 - 1969. They are fairly common, casting numbers start with C6OE-...
    1968-69 Ford Mustang disc brake spindles are specific to the common single piston calipers as found on Fords way into the 1970's. They will work the same as Granada, but you will need to change your outer tie rod ends. Casting numbers start with C8OE-...
  3. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    I bought a set of those that were on a 71 Comet. They work, but I believe you will need the earlier tie rod ends for them since they are the smaller 67-68 Mustang size. - Matt
  4. Krazy Comet
    Yep I have them on my Comet, used tie rods for a '69 Torino...
    These are exact same brakes that are on my Cobra Jet...
