'68 Mustang Fuel Sending Unit on a '71 Comet
Discussion in 'Parts Interchange' started by Cigarsnob, Jan 25, 2015.
  1. Cigarsnob
    Cigarsnob Member
    San Jose
    1971 Comet
    Found in this thread: http://mmb.maverick.to/threads/fuel-sender-unit.86174/#post-872386
    from Mad Goon that he used a '68 Mustang fuel sending unit in a '71 Comet. I need a new fuel sending unit for my '71 Comet and I found this part for a '68 mustang that is $50 cheaper than what I found for my '71 Comet. How do I tell if the Mustang version is compatible?
    Here's the one I'm thinking about getting:
    EDIT: Ooops! I supplied the wrong link. Here is the correct one
    http://www.summitracing.com/parts/sdk-c8zz-9275-c
    Also, is there a rule of thumb of compatible parts between a Mustang and Comet? Just curious as it seems like the Mustang parts are cheaper.
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    You would have to compare the Mustang reproduction one side by side with your OEM Ford Maverick fuel sending unit.
    It primarily has to do with the inside shape and dimensions of your fuel tank. The pickup tube with sock, needs to be at the lowest portion of the fuel tank to draw all of the fuel. The float needs to touch the bottom and the top of the tank, at the extremes.
  3. Cigarsnob
    Cigarsnob Member
    San Jose
    1971 Comet
    Thank you krelboyne. I got my new unit in yesterday and immediately noticed a difference. The Mustang one has a single post while the Comet has two post that connects to the cable. It will work once you make a new cable for the Comet as I tested it last night.
    Once I get my take back from the shop, I will check to make sure the pickup tube sits at the lowest portion and the float hits both extremes.
    Thank you for your reply
