'70 drag car owner
Discussion in 'New Members Forum' started by AHapp88, Nov 21, 2013.
  1. AHapp88
    AHapp88 Member
    Indiana
    79 F100, 70 Mav
    Just bought a '70 Mav drag car that has been sitting for 8 or so years, so it's restoration is underway. It has a 10pt cage, frame connectors through the floor tied into the cage, leafs moved inside the frame rails and mini tubbed on a 29.5x10.5W, with Center Line Convo Pros. It's gonna get a 408 Windsor that I have collected most of the parts for, and a manually shifted C4. The car used to get the front wheels a couple feet high with a 347, so it should be a fun ride !
  2. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  3. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    :Welcome: from the Great Northwest! Sounds like a lot of fun
  4. olerodder
    olerodder Member
    NorCal
    Welcome from another 70 Maverick drag car owner. Sounds like a great
    project to bring an old racer back to life.
    Mine started out as a B/SM car in 1979 and still has the participant sticker from the 1979 Winternationals in Pomona, CA.
    Mine also has a 10point cage with 5gal cell in the trunk. When it raced B/SM in the late 70's/early 80's it had a Boss 302 and 4spd and was turning in the mid to low 10's. It currently has a 408/Powerglide and has turned a 9.801 in the 1/4. It has an old but very effective ladder bar setup and has been tubed to accept 13" tires. I have refreshened the motor (it was dyno'd at 644hp @6800 and 544ftlb of torque @5700) the trans has been refreshened along with the 9" and upgraded to 33spline axles. It did have drums on all fours but I have put disc's in their place.
    This is a great forum with years of experience..............send pictures when you get enough posts:Handshake
  5. 71gold
    :Welcome:...:Handshake
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  7. mav1970
    :Welcome: from a fellow 70 owner in Northeast Pennsylvania
  8. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Congratulations on your purchase,I did the same thing back in Feb. of this yr.Mine was set up very similar to yours only I`m going to run a stick,much more fun to drive.I don`t give a rats rear about bracket racing because I`m going a diff. direction.:chirp:
  9. Craig Selvey
    Welcome from a fellow Hoosier.
  10. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada!
  11. WinterBlue71
    SC
  12. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Welcome from Ky. Where in Ind. are you?
  13. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    He's right accross the river from me Ward! :yikes: Gonna be two of us at the track now :thumbs2:
  14. AHapp88
    AHapp88 Member
    Indiana
    79 F100, 70 Mav
    Evansville, like Tom said, and I work in Hendo. I plan on running at CMP on Saturday, and BG on Sunday, if I can afford to do both. I really like Beacon's track, but CMP is so close that I probably won't drive to Paducah too often.
  15. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    That`s pretty neat,my car came from Evansville,previous owner was Mike Bush if you know him.I know when I bought mine,Mike said his brother had one he wanted to sell also.I did`nt see the car but it was set up for drag also,had a full halo cage around driver.Mike said he installed it because his brother had rolled another drag car he had & was concerned about his safety.408 is the way to go,it makes these little cars rockets & they are hard to beat if you can drive it.
