70 maverick
Discussion in 'Technical' started by BeastModeMav, Mar 15, 2016.
  1. BeastModeMav
    BeastModeMav Member
    las vegas
    70 maverick
    i have a 70 maverick it had a 200 cid engine I sold the motor and im purchasing a 302 it has the c4 transmission I was wondering if the c4 will bolt up to the 302 or do I need a bellhousing and converter change..thanks..
  2. Craig Selvey
    Yes you will need a bellhousing and a converter, as well as a flex plate for the motor.
    Your transmission might not hold up to a V-8....yours has less clutches in it. A rebuild will cure that.
  3. junrai
    junrai Member
    rancho cordova ca
    instead of dealing with finding a bell housing just go buy a newer c4 and be done otherwise your trans is going to crap out on you and youll end up doing hte same thing anyway.
    the trans for the 200 is visibly smaller than the c4 the v8 hooked up to
  4. mav1970
    :Welcome: from a fellow 1970 owner in Northeast Pennsylvania
  5. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Hope everything goes well for you & you don`t have to many headaches getting it all worked out.
