71 AC vacuum lines
Discussion in 'Technical' started by bvergeer, Dec 20, 2022.
  1. bvergeer
    bvergeer Member
    Tennessee
    1971 2 Door
    My 71 was born a 200 I6 was A/C. Somewhere in the process is swapping in the 302 the vacuum lines going through the firewall were cut and I’m guessing that’s why I don’t have any defrost control.
    There are 4 lines coming through the firewall, based on the pics below does anyone know which need to be connected and if full vacuum from the intake tree is appropriate?
    EDB92F2A-118D-4F04-A3BD-D9D5289445FE.jpeg EA42A7E7-BA4A-4B25-B3B7-E63FF5984CB6.jpeg
    thanks,
    Bob
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  3. T6pilot
    T6pilot Member
    Maverick
    I have a 72 with the 200 I6 and A/C. One of those lines is a wire that would go to the A/C compressor clutch. Two lines ( brown and green ) would go to the vacuum controlled hot water valve - shuts off coolant flow through the heater core when A/C is called for. One line partially closes the valve and the other results in full closure. The other vacuum line would be the vacuum “ feed”which gets input from the vacuum canister. The canister gets its vacuum from a port on the intake manifold. Hope this helps.
  4. bvergeer
    bvergeer Member
    Tennessee
    1971 2 Door
    Thanks guys, those help. I need to source a vacuum canister and hot water valve to get this fix sorted.
