71 Grabber w/ power assist steering
Discussion in 'Technical' started by vernbray, Oct 25, 2009.
  1. vernbray
    vernbray Member
    San Jose, CA
    '71 Maverick Grabber
    :huh:Previous owner tried to convert over to a power assisted steering. The issue is that the cylinder hits the headers, even with the lowered bracket. I could just move the the bracket and then weld it in place, but that just does not sound right. It also looks like it would still be too close to the headers and I'm concerned about overheating the fluid in it.
    I'm contemplating on returning back to a manual steering setup for the time being. Can I just remove the cylinder and power steering pump & hoses, or will I need replace the original steering setup? I still have access to it.
    5.o engine out of a 93 Mustang
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    The best way is to change it to a manual center link. You could buy one of those adapters from one of the Mustang houses that replaces the control valve, but if you still have the original manual stuff, it would be better.
  3. maverick maniac
    maverick maniac Banned
    owensboro ky
    some of the cheap headers just do not clear power steering stuff
  4. vernbray
    vernbray Member
    San Jose, CA
    I'm going back to the manual for a while, but will keep the power steering set-up in storage. I may want to revisit this later. I also may just convert over to a rack & pinion at a later date. The next issue is that the '93 5.0 has a serpentine belt and I will need to build a bracket for a dummy pully after I pull the power steering pump.
  5. Rando76
    Rando76 Member
    Claremore, OK
    Remember that the gearbox is different between power and manual setups too. The power will work, it's just stiffer.
