71 Maverick Gauge Cluster Not working..still!!
Discussion in 'Technical' started by Maverick Barber, Nov 28, 2008.
  1. Maverick Barber
    Maverick Barber Member
    Dallas, Georgia
    1971 Ford Maverick
    Well it's me again..I am at my wits end trying to figure out why my instrument cluster is not working. I have replaced the small fuse and replaced every bulb behind the cluster panel but still a no go. If the headlights work does that necessarily mean that the gauge cluster is getting juice to it? I am trying to prevent an electrical shop from taking advantage of a simple issue. As always any help is much appreciated...Maverick Barber
  2. rthomas771
    A bad light switch will allow the head lights to work but keep the dash lights from working. A bad ground will do the same. Electrical problems are hard to trouble shoot over the internet.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Might be a bad rheostat on the light switch or they are dimmed all the way down. Have you turned the light switch knob to see if it makes a difference?
  4. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    not only rotate the knob for the headlights clockwise and back but jiggle it while you are rotating it. mine has a couple dead spots in it that if you turn the knob to dim the lights and it hits a certain spot the dash lights go out all together
