72 250 distributer points setting?
Discussion in 'Technical' started by dodgeboy01, Jul 31, 2017.
  1. dodgeboy01
    dodgeboy01 Member
    canada
    1972 maverick
    wondering about the setup for the distributor points on a 72 250. just bought new points and forgot to measure beforehand,
    thanks -aj
  2. Doug
    Doug Member
    washington state
    71 maverick grabber
    .015 mm
  3. 71gold
  4. Krazy Comet
    NEVER trust a installed points set to be of correct gap, contact and/or rubbing block wear is the main reason they require replacement...
    Point gap for a 6cyl should be .025"-.027", or if you have a dwell meter, 35*-40*...
  5. rthomas771
