72 front disk brakes (hard line questions)
Discussion in 'Technical' started by bowstick, Aug 17, 2008.
  1. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    I was wondering if i needed to new lines for my 72, obviously im doing the drum to disk brake swap.
    I also was wondering if the re manufactured master cylinder would work.
  2. Dave B
    I left the steel lines the same on my 73 when I converted to disc's, and left the drum master cylinder, but I did use flex lines from a 74, them seem to have worked.
  3. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    the flex lines are just to the calipers....and are about a foot long....?
  4. Dave B
    Yup, I can measure one, I have some spares.
  5. Jamie Miles
    I used a couple of unions and a couple of pieces of pre flared brake line form the auto parts store and extended mine. That was over a year ago, and the car gets driven pretty much every day.
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    yes :)
  7. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    your steel lines are fine. You will need the new line Dave mentioned. When I did the swap my 70' I got the rubber line from ADVANCE.
  8. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    does the lines come with the banjo bolt and what about the fittings?
    do they match up
  9. Jamie Miles
    So, am I reading this right that the rubber lines for a disc brake equipped '74 will allow you to use the original drum steel lines with absolutely no modifications? :hmmm:
  10. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    thats what im wondering because if so ....it would be GREAT!!!
  11. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    My car is a 70....the disc brakes came from a 74' I went to advance and picked up brake line.....screwed them on, bled the brakes and have been this way for more than 2 years. I did this so I know there was NO MODIFICATIONS! :thumbs2:
    This is just like the headers I run on my car....there are folks on here that say they do not fit on a maverick.....but yet I have them on my car :hmmm: Not always is the always right people right :Handshake
  12. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    the fittings fit perfect?
  13. Dave B
    They did for me. I unscrewed the flex lines for the drums, swapped the spindles, installed the the rotor, caliper, flex line, bled the brakes, and I was done. I drove the car for awhile like that, that was before I tore it down to paint. Plus when I ordered the new stainless brake like, I ordered the drum lines, they were the same.
    This is the only picture I can find, it's from when I was tearing everything down.
  14. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    DITTO (y)
  15. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    just to make sure.. yall DIDN'T have to change the proportioning valve
