72 Grabber Emergency Brake Cable
Discussion in 'Technical' started by Slider28, Jan 13, 2018.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    I noticed a while back that my emergency brake cable is resting under the drive shaft and it is half way eaten through. I don't see how to reroute the cable, surely this isn't how Ford designed this! Are cables still available?
    Thanks!
    Chaz
  2. Hotrock
    Munroe Falls, Ohio
    My parking brake cable runs below the driveshaft but does not even come close to touching it. Your Maverick does not appear to be overly lifted in the rear thus causing an exaggerated driveshaft angle and therefore cable interference? :huh:
    Melvin's carries cables.
    http://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadffejo
  3. Craig Selvey
    Here is how it should look. It is not touching the exhaust.
    Shorty and Hotrock like this.
  4. Slider28
    Slider28 Member
    San Antonio, Texas
    Thanks! I will look at it again! BTW!!!! What a SEXY underbelly !!!!:cheers:
    Craig Selvey likes this.
  5. Jerry
    Jerry Member
    Woodstock, GA
    77 Maverick 2dr 302, 74 LDO
    It doesn't appear that Melvin's has the front brake cable for a 73. Anyone know where to find one?
  6. dyent
    dyent Member
    vancouver bc
    Try contacting this fellow, he manufactures these e-brake cables, ask him about ones for 73's.........
    https://www.ebay.com/itm/Bruin-Brake-Cable-92437-Front-Ford-Fits-70-72-Maverick-MADE-IN-USA/121092223020?fits=Make:Ford|Model:Maverick&hash=item1c31a8b02c:g:56YAAOSwfpVZLaNF
    Ford part number: D3DZ-2853-A
    AutoKrafters has new repro ones.............
    https://www.autokrafters.com/p-22591-brake-cable-front-1973-74-maverick-comet-d3dz-2853a.aspx
    http://www.exmotostore.top/nos-1973-ford-maverick-front-brake-cable-d3dz2853a-p-17833.jsp
    http://www.rearcounter.com/D3DZ-2853-A-parts64323.html
    David
  7. Slider28
    Slider28 Member
    San Antonio, Texas
    Sorry! It wasn't the Driveshaft that
    was rubbing, My brain is getting old! It is rubbing on the duel exhaust under the car. and the cables are 1/4 of the way through. If they snap will the brakes lock up while I am driving?
  8. 71gold
    no...you just want have an E-brake...:bouncy:
  9. dyent
    dyent Member
    vancouver bc
    Also, if you are driving and the rear ebrake cable breaks, you could loose the rod on the arm and the rod on the frame..........not to mention possibility of cable wrapping around something!
    David
