73 Comet.....Limited slip rear end???
Discussion in 'New Members Forum' started by BluComet, Mar 7, 2009.
  1. BluComet
    BluComet New Member
    Saskatoon, Saskatchewan. CANADA
    73' Comet 4dr 302.
    Is it possible that my 73 Comet (all orig. with a #'s matching 302/C4) could have come standard with a limited slip rear end???...I believe the rear end gears are 273's
  2. rayzorsharp
    :disagree: Probably 2.79's but no limited slip.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Mavericks and Comets were NEVER available with anything but open diffs 69-77.
    2.79 and 3.00 were the only gears available when equipped with an 8".
    It has been a long, long time since the car was new though, so a previous owner had plenty of time to install anything you can imagine.
  4. maverick75
    put it in gear, raise up the rear end and turn one of the tires. If they turn the same way then you have a LS if they turn opposite ways then you have an open.
    unless you want an all out performance car you dont need one, an open diff is perfect for cruising.IMO
  5. BluComet
    BluComet New Member
    73' Comet 4dr 302.
    Thanks for the info guys, and yes I'm sure your right about the 279 gearing.... Does anyone know of an interchangeable 8" rear end I could use that would have a limited slip and some gearing I could squeal the tires with?(at least mid 3's)http://mmb.maverick.to/images/smilies/huh.gif
  6. maverick75
    the mustang II's,bobcats and pintos also came with 8"s and some had track lok's but they are extremely hard to find, i've been looking for 4 years with no luck.
    this link might help you out http://www.mustangii.org/decoder/axle/
  7. Jamie Miles
    The whole center sections with what ever gear you want already installed are usually ebay. Not cheap though.
