73 mav windshield leak
Discussion in 'New Members Forum' started by 1967carguy, Jan 10, 2012.
  1. 1967carguy
    1967carguy New Member
    oregon
    1973 ford maverick
    has anyone had to fix a windshield leaking? my daughters 73 mav is dripping water on the floor boards. I pulled fenders off and cleaned out cowl drains , i pulled out about a coffee can of pine needles out of each side. I sealed all the seams and thought I had the water leak fixed I washed the car and found it was still leaking. after more research and standing on my head under the dash It looks like water is leaking in at base of windshield. I called local glass guy and asked him about it and he said he dident want to mess with it from past experinces with mavericks and mustangs. are they that hard to get them to stop leaking? if anyone has had that problem let me know thanks !
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    You may want to look at your cowls.....a very prone area
  3. hotrod-daddy
    hotrod-daddy Member
    most headliners come out when the windshield is removed....You may get lucky by removing the trim and silicone the crack
  4. mercgt73
    +1
    Take a hose and run water into the cowl area, through the cowl slots below the windshield (check both sides). Then watch for leaks under the dash. If you see a leak, then your cowls have rusted through. If no leak, then good for you! It may just be the windshield.
    Do a search for "cowl repair" to get some pictures of where bad cowls leak.
  5. injectedmav
    injectedmav Member
    Georgia
    I've had good luck using a flow grade urethane that a glass guy gave me if the windshield is leaking. Make sure the rubber hasn't separated somewhere around the glass and it should be very clean and dry before application. The cowl leaking is more likely if the rubber looks good especially if you cleaned a bunch of forestry out of there.:tiphat:
  6. Craig Selvey
    When doing this.....get NO water on the windshield or around the windshield.
  7. 71gold
    you may want to pull the heater box and clean out the top hat and box. i had one leak and it was pine straw in and above the opening for the freash air. it was wicking water through the pine straw...
  8. 1967carguy
    oregon
    1973 ford maverick
    thanks for all the response on that leaking windshield . I think im going to try to clean all the old sealer out around the windshield and rubber and try to reseal it . I think the cowl is ok the leak looked like it was coming form the base of windshield .
  9. Mavman72
    Be certain it isnt the cowl...Run some water through there. Hate to see you do all that trim removal,cleaning/scrapeing only to have the same leak afterward...Good luck!!!
  10. 71gold
    suggestion...get a new seal...once you start messing with the old seal, you could make it leak more. these seals are very brittle after...39-40 years...:yup:
    Frank
