73 Maverick weight
Discussion in 'General Maverick/Comet' started by cityboy, May 29, 2003.
  1. cityboy
    cityboy Member
    Reynoldsburg, Ohio
    73 maverick
    Does anyone know how much a 73 maverick weighs,or how much the hood weighs in comparison to a fiberglass hood.
    Also, I am wondering about how much the factory front buckets/rear bench weigh together.
    If anyone can take a stab at it I would greatly appreciate it.
    Thanks Steve
  2. cityboy
    cityboy Member
    Reynoldsburg, Ohio
    73 maverick
    Anyone?
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    weight
    The seats in my '72 weighed an awful lot at least 150lb between them.
    as far as total vehicle weight, it's pretty hard to say.
    depends on motor, trans, options and such.
    the hoods are pretty light, but of course a glass hood will always be lighter.
    I weighed mine with the front seat out, all the rubber mat and sound absorbant material removed, the rear seat installed, reeeeaaly heavy back tires, 3/4 tank of fuel and me in it and came up with 2710lbs I have a 302 with aluminum heads and intake.
    You can get 'em much lighter (I'll get there eventually).
    Fordman has his down to 2400lbs!
    Use the search button and type in weight.
    It'll pop up lots of threads.
  4. Lightning
    Lightning Member
    Saskatchewan ,Canada
    1971 comet GT
    Glass hoods (pinned or 1/4 turn style) weigh less than 15 pounds .
    I would say a steel hood with hinges would be around 75, maybe less
  5. cityboy
    cityboy Member
    Reynoldsburg, Ohio
    73 maverick
    Do you guys think that relocating the battery to the rear really helps that much?
    Also, are fuel cells any lighter than the factory tank?
    Thanks Steve
  6. Darracq
    Darracq Member
    Re
    I weighted the front bumper off of my 73 and it was 85 lbs with all the brackets, Get that thing off there LOL
  7. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    i just took my 73 comet to the scale the other night at a truck stop (CAT sert. scales) it was 3000 lbs,Full interior 1/2 tank gas,289 ,C4, 8 in,All steel. 1720lb front,1280lb rear
  8. Mavaholic
    I weighed my Sprint at a Cat scale too. It was 3240 with a full tank of gas and me. I'm about 230. I have alum heads, intake, radiator and the battery in the trunk. The rear mounted battery helps in weight distribution. Mine was 1660 front and 1580 rear. pretty close to 50/50
