'73 running real rich.
Discussion in 'Technical' started by blackpony, Nov 16, 2005.
  1. blackpony
    blackpony Member
    SC
    73 2 door
    My wife's '73 has an '80 302, .30 over, stock heads and bottom end, a holly 650 DP, a stealth intake, hedman long tube headers, and a mild comp cam.
    This car is driving me nuts! It's runs exteremly rich. It will foul out a new set of plugs in just a few minutes. We have checked the timing, the ignition, and even tore the holly apart (even though it's brand new).
    Any ideas?
  2. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Way too much carb for one thing. Probably needs to be jetted down. I had the same probs on a 302 I had. Switching to a 600 Vac Secondary cured it right up.
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    try adjusting the float levels as well, and make sure the float needles are seating. if the carb is working correctly, im with stockhatch on that. I switched to an edelbrock though.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Your carb is NOT too much.
    It is far from an economy carb, but it is sized right.
    You just need to take a deep breath and read up voraciously on Holley tuning. Once it is tuned correctly, it will run great for a very long time.
    What tranny do you run?
    What gears do you run?
    Those play to the size squirters, pump cams, and diaphram volume you need.
    General areas to check:
    Float levels (sight plugs on the side of each bowl... I use clear plugs)
    Fuel pressure (unlikely, but can override the floats)
    Sticking choke (obvious, but I had to throw it out)
    Ruptured or malfunctioning power valve
    Misadjusted pump linkage
    Jet sizes
    Other considerations:
    Too large accelerator pump 5cc vs 3cc
    Too large squiters for gear ratio
    Check valve missing from below squirters (allows engine to suck fuel through squiters)
    Idle mix screws
    Age of carb (you say new, but when was it built... power valve protection has only been standard for a decade or so)
    Give it a chance, and read, read, read... everything you can about Holleys, your model in particular. They are the absolute best carb, but you have to do it right. Whatever you do, don't go to an AFB (Edelbrock) unless you just want an economy part.
    Good luck
    Dave
  5. Earl Branham
    Lugoff, SC
    blackpony; Like Dave said, check all that...I have a 600 vacuum sec. and the power valve ruptured, and it caused all kinds of heartache. Ran rich, stalled and chugged when going slow, belched black smoke. Hard to believe that little valve can cause all that. Good luck!
