GOT A 74 MAV 200I6....PUTTING A 76 302 MOTOR IN....CAN I USE THE ALTENATOR, POWER STEERING PUMP, ETC. OFF THE 200 MOTOR
As the old saying goes: You can use anything you want as long as you can make it fit. The alternator should work with the appropriate brackets but it might be better to upgrade to at least a 60 amp unit at this time. I doubt the same steering pump was used. Even if it is the same you will need different brackets to mount it to the V-8. As for the "etc." it depends what that is.
