76 maverick 2 door
Discussion in 'General Maverick/Comet' started by DRUNK, May 19, 2011.
  1. DRUNK
    DRUNK Member
    washington state
    1976 maverick
    i just bought a new gas tank now i just need some help with were can i find the darn sending unit for it dose eneyone know were i can find one at thanks for the help.
  2. maverick75
    I've checked around and they're not available at all. Autokrafters used to have them back in the day but not anymore.... Best bet is to buy a used one and hope it doesnt go bad.. or you can try this one:
    http://mmb.maverick.to/showthread.php?t=53969
  3. DVCRobin
    DVCRobin Member
    Nashville, TN
    1976 Maverick
    I had this same problem this fall. I ended up going with using my old one and praying that it doesn't fail. So far so good.
    What I found out is that the early year sending units will work, but they will not pick up the last 3 +/- gallons of gas (unless you do the mod to make the pick up longer). So you will be holding 3 gallons of gas you can't use.
  4. Moneymaker 1
    Panama City Florida
    I got mine out of a Torino with a 19 gal tank at the Pick n Pull here, works great...very accurate, when I ran out of gas it showed it was empty lol.
  5. DRUNK
    DRUNK Member
    washington state
    1976 maverick
    ok thanks i think ill go with the 65-68 mustang one i think i wii make it work thanks.
  6. maverick75
    Same here, i'm running a 74 one which is the same as 71-73. But it marks accurate. I'm going to swap out to the mustang one soon. Because this one is 36 years old....and I don't trust 36 year old electronics.
  7. jdproper37
    jdproper37 Member
    Fargo, ND
    1977 Ford Maverick 4dr
    Can you explain about the mod making the pick-up longer?
    Jason
  8. DVCRobin
    DVCRobin Member
    Nashville, TN
    1976 Maverick
