8 in. or 9?
Discussion in 'Technical' started by mav302, Jun 15, 2012.
  1. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    what's the easiest/best way to determine if I have a 8 or 9 inch under my car?
  2. Fastkarz
    Fastkarz Member
    Northern NJ
    1972 Maverick Grabber 347/AOD/4.11
    Use a deep 9/16" 3/8 drive socket on the lowest bolt.
    -If it slides on straight it is a 8" rear
    -It if won't go on straight and is pushed down by the pinion bearing housing then it is a 9"
  3. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    thanks..ill do that
  4. 71gold
    that's a good answer...:thumbs2:
    I was going to say...look at it...:tiphat:
  5. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    nine inches have rounded center sections and eights are flat on the top & bottom.
  6. baddad457
    Uh, nope..........................The early 9's look a lot like an 8" rear. The socket test mentioned above is the best way to I'd one. If oyu can get a socket and ratchet on the two bottom nuts, it's an 8. If not it's a 9.
  7. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    well most of them anyways :D
  8. rthomas771
    I don't think Seth was talking about the enforcment webbing. The 8" center section is more flat on the top and bottom than a 9". Look at the gaskets and you will see the difference in the shape
  9. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    You are correct. Sorry for being a little vague, but I believe he is right about some 9" axles housings having a flat spot on the top and bottom of the case. Also over the years there are many changes the the ribbing of the 3rd members and housings so it all has lots of variables to consider.
    This is a great site:thumbs2: http://www.kevinstang.com/Ninecase.htm
  10. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    quick question, did any 9" axles ever come with 31 spline from the factory?
  11. baddad457
    Yes, most of the later ones in pickups, Broncos (the full size ones) and vans had 31 spline axles. Talking about from around 77-to the end of production. Most of the early 9's before 77 were 28's.
  12. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    This is just in idea, but i was thinking about buying a 9" and cutting it down.
  13. MikeG747
    MikeG747 Member
    Arkansas
    Street only or race?
  14. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Street mostly, i'm debating about cutting down a 9 and putting new shafts, (not sure if i could get the old ones cut or if i could fine new ones) gears, and posi
    verse buy a gears,posi and new axles for my 8" that im using now.
    I was looking on ebay at the chunks with trac-loc and i saw one that said you could buy 28 or 31 spine carrier. I didn't think it was possible to put a 31 spline axle in a 8 inch,...or is it????!?:hmmm:
    BTW sorry about the thread hijack.
  15. Bryant
    you can put 31 spline axles in a 8". several company's make lsd's that are 31 spline. also several companys sell cut to fit axles that have the small axle bearing end and are 31 spline axles.
    ive done quite a few of 8"s this way. the nice thing is that you can use these axles in a 31 spline 9" if you ever need to step up to one.
