89 5.0L ho roller
Discussion in 'Technical' started by Gysgtjerry, Sep 11, 2006.
  1. Gysgtjerry
    Gysgtjerry Member
    Kansas City Missouri
    1973 Maverick
    Would like some input as to the best ignition/distributor to use on a 5.0L ho roller engine in a 73 maverick.
    Thanks
    Gunny
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    im running all msd , pro billet dizzy, msd 6al box ,blaster 2 coil, but i know alot of guys use duraspark , many different options
    eddie
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    lots of choices... IMO, run all MSD.
    I would buy a complete set from the same manufacture, makes install alot easier.
  4. eddie1975
    Martinsburg, WV
    sold
    yup :agreed: , im no master mech. or anything , but i would have say it was easy to install all my MSD parts
  5. Cleaver
    Cleaver Member
    MD
    Chel
    I just run a duraspark with an accel coil on my truck. MSD box will also drive a duraspark distributor. Of course you have to splice or re-connector wires. Whatever distributor you get, make sure you run a steel or bronze dizzy gear with the roller cam. It will slap eat up an iron gear.
    Cleaver
  6. Dave B
    MSD all the way, it's worth the money!!
  7. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    If it's basically a stock motor and going to see mostly normal street use, you can use a Petronix setup very well. Buy a rebuilt distributor for $40, put in Petronix Igniter, and use a Petronix coil. It will all look stock and give very good performance for the street. I ran this setup in a '73 Mav that I sold. I have Petronix in my '77 Mav with a 250 six-banger.
  8. don graham
    i run msd distributor, 6al box and a blaster ss coil from msd. i think the msd distributor came with a brass gear to change it out if i remember right.:)
  9. eddie1975
    Martinsburg, WV
    sold
    my msd pro billet came with iron gear :)
