9'' posi ? ? ? ?
Discussion in 'Technical' started by 302-72-mav, Jan 14, 2011.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    i just got back from pick n pull
    and i found a 78 F100 or F150 ? VAN with a 9'' rear and it has a small 1'' tag and all it reads is 3.56 32-sun 9-pin
    so i am wondering if it is posi
    when i turn one axle the other spins the other way but if you try to stop it it won't turn unless you use 2 breaker bars one on each end
    if you try to spin bolth axles to the front it won't move
    but if i spin the driveline bolth axle's will spin towards the front ?
    so i pulled the thirdmember and the numbers i got wer
    WAR4206A and A14 that was on the housing that bolts to the sun gear
    case number is WAR 4025A
    the unit where the sun gear bolts up (where you see the bolt heads) is all smooth no casting / rough look and i don't think it was resesd around the bolts ?
    i didn't have enough time to take it apart and see if it had clutches because they wer closing
    just wondering if it's a posi unit or not if so then i am going back to get it
    they charge 80 + tax ---- about 90 bucks out the door
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    3.56 should be the gear ratio.
    Should have a "3." then a gap, then "56".
    "3. 56"
    If it was a "posi", it would be:
    "3. L 56"
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    it's a 1'' tag not the stock one
    might be somthing a shop made ? it's the size of 3 pennies next to each other
  4. rthomas771
    Ford never made a Posi...G.M. did.
    If it was in a van then it would be a E series, the trucks are F series.
    The reason it turned the other way is because it's an open rear end. WAR case was made in the late 50's and have 2 vertical rids like a N-case. 4026-A is the part number. A 14 is a date code. Rear ends don't have a sun gear. It is worth $90 if you don’t go drag racing with it every week end.
  5. rthomas771
    Early rear ends have a tag like this.
    [​IMG] [​IMG]
  6. mav1970
    With my 9 inch rear that has a traction lok unit, both tires spin the same direction when you spin the yoke.
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    my tag looks just like that tag but with 3.56
  8. 3154tm
    3154tm Member
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Seems you guys get a bit defensive about terminology. I think posi became the general accepted term for a limited slip diff years ago (may be a regional thing) and was no longer a reference to brand identification. When I was in tech school here and in Phoenix the instructors referred to them as a "positive traction type differential" or posi for short. Seems kind of petty to continually correct people over it. This is not directed at you, just seems to reoccur on this forum regularly.:huh:
  10. maverick maniac
    maverick maniac Banned
    owensboro ky
    yes it does and is really unnecessary
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Yep,,, I just had to wipe my eyes with kleenx,,, sorry, I mean tissue,,,
  12. 71gold
    is...necessary...if one is GM and the other Ford...
    ...also could be a price difference at a...rearend shop...to rebuild...
    ...:yup:...
  13. mav1970
    Are uou sure you didn't mean handi-wipes :tiphat:
  14. injectedmav
    injectedmav Member
    Georgia
    If it is a 9", it's a Ford. Terminology doesn't really matter. Limited slip, locker, posi, positraction, I really don't think it matters. The axle also could have been fitted with a locking diff after the factory build and not tagged. We do it all the time. If you turn one axle and the other turns the same direction without holding the pinion, It's a locking or limited slip diff. If you hold the pinion and the other axle spins the opposite direction, it's an open diff, but it's still a 9" and worth $90 in my book.(y)
  15. rthomas771
    Let's call all four barrel carburetors a Quadrajet even if it's a Holley or an Edelbrock. We might as well call fuel injection a carburetor also. The same goes for a Tubro350 and C4. Does it really matter? Aren’t both a 3-speed automatic?
