9" rear
Discussion in 'Parts Interchange' started by seth, Jun 17, 2012.
  1. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Just wondering if you guys could give me an option on this rear on craigslist.
    I was thinking about buying it cutting it down and getting new axles/trac loc
    what do you guys think. Is it a worth doing all of that? is that axle even from a F-series?
    http://baltimore.craigslist.org/pts/3053744146.html
  2. rthomas771
    The chunk itself is worth the $85
  3. maverick75
    x2
    31 spline and 3.50 gears are two huge pluses.
  4. rayzorsharp
    I could sell that chunk for $250 easy. Wish I had several of them.
  5. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    im thinking about it, my worry is that something might be broken since is been used to 4wheel.
    as i was looking at it he changed his price to 110
  6. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    If it was used to wheel, "hard wheeling" the axle tube,s could be bent..
  7. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ya i think i may pass, mainly because im not sure how i would go about getting the right axles for it once i cut it down. plus if i wanted to i think i can get one from a 79 ford truck i saw at the pick and pull for 65 if i change my mind
  8. baddad457
    Your best bet to finding a "more than 3.00" ratio 9 with trac-loc is looking under a big Bronco. Not all have been "used hard and put up wet" I bought the one I used as a parts source from an 81 Bronco, it had 3.50's, trac-loc and 31 spline axles. I did have to replace the outer pinion bearing as it was pitted, but the gears and trac loc unit were fine.
  9. 71gold
    any eBay "deal" you get on rear end stuff I would be suspect of...:yup:
    local, knowing the person, maybe...:tiphat:
    ...JMHO...
  10. Rick
    Rick G8I operations
    Ocala, Florida
    Head down to Crazy Rays in Jessup. I got my 9" there for $65 out of a Bronco. Got it home to find it had 4.10 gears with a spool. Took it to Autofab and had them shorten it and add new axels, perches etc. Been hamering it with a transbrake since.
  11. super maverick
    super maverick New Member
    virginia
    1970 ford maverick
    I have one for sale.make me a reasonable offer it is under a maverick
  12. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    That's a good score.
    I'm debating rebuilding a 8" or cutting down a 9" :hmmm:
  13. baddad457
    To me, this is a no brainer, go with a 9. You will spend about the same $$$$ on an 8 and still have an 8. Spend it on a 9 and your resale value goes up accordingly.
  14. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ya im not sure what im going to do, i think im going to try to price it out first.
  15. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Do you guys know how to tell the difference in a posi rear bronco?
