9" upgrade
Discussion in 'Parts Interchange' started by earl74, Sep 13, 2016.
  1. earl74
    earl74 Member
    san antonio tx
    1974 maverick
    Wht year / makes of cars will have a bolt in 9", granada?, installing in 74 mav, the versai is to hard to get but would love disc if not then will convert
  2. mav man
    mav man Member
    wi
    70mav
    59 Ford custom or rancharo are direct bolt in ,they are about 1/2 or less wider if I recall.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Many early Mustangs/Cougars will bolt in as well since the axle perches are located in the correct position, but the tube lengths are different.
  4. mav1970
    A Lincoln Versailles is an automatic disc brake 9 inch find but there are still Granada and Monarchs out there and some have 9 inch rears under them. Some are disc and some are drum. Some are 6 cylinders and some are V8's. No one has ever figured out which one of them got the 9 inch rear so look under all of them and you could get lucky. Mine 9 has disc brakes and came out from under a 6 cylinder Granada Ghia :1st:
  5. baddad457
    I've seen two 1980 Granadas with the drum 9 under them. I figure this was the last year for a 9 in the cars, so Ford might have been trying to use up stock.
  6. mav1970
    In 1981 the Granada/Monarch was built on the Fox platform so that might have had something to do with the 9 inch disappearing in 80
  7. grumpysrg
    grumpysrg Member
    Elyria , Ohio
    Had a new 71 302 c4 2dr 1971.
    I used a 57 Ford 9 in. in my 71 Maverick it fit right IN I had to push my springs outboard and it didn't take much .
  8. Buck62
    Buck62 Member
    Chicago IL
    1974 Mercury Comet (Base)
