94 Toyota pick up with a 302?
Discussion in 'Other Automotive Tech & Talk' started by wjtkb, Jun 13, 2013.
  1. wjtkb
    wjtkb Member
    keystone heights fl
    maverick, 94 toyota pick-up, 94 honda accord
    Has anyone ever tried to put a 302 with a t5 into a toyota pick up?
  2. Dave B
    Why? ..........
  3. wjtkb
    wjtkb Member
    keystone heights fl
    Because I have a spare motor and the truck needs a motor and a trans, and I have my daily driver already, just a thought ive been thinking
  4. wjtkb
    wjtkb Member
    keystone heights fl
    Its sort of like putting a 302 in to a ranger
  5. Dave B
    But it's a Toyota, not a Ranger. Rangers are cool.
  6. wjtkb
    wjtkb Member
    keystone heights fl
    Rangers are just awesome, id never trade mine in. Nobody could ever say that they would know whats under the hood lol
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I put a Buick 231 V6 with a Saginaw 4 speed into a 78 Toyota pickup. It was pretty easy, just had to make mounts and a tranny crossmember. I even used the stock Toyota hydraulic clutch slave cylinder, just had to build a new bracket and use a longer pushrod. It was about the same length as the stock 4 banger, I figure a 302 would need a recessed firewall. It would be a Hoss if you did it, you'd probably need 500 lbs of lead in the back bumper just to get traction! :rofl2:
  8. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I'm sure someone makes a conversion kit, someone I know has an early 90's 4 runner with a 350, so maybe the make sbf mount too.
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Maybe........ Not mine but for sale locally.
    http://kpr.craigslist.org/pts/3848030250.html
    88 Toyota 4x4 4" suspension lift with rear springs not blocks 1967 ford 289 small block runs great lots of aftermarket parts carb intake ignition c4 auto tranny adapted to Toyota tcase this conversion was done with all aftermarket mounts 35" swampers nice wheels only problem is truck was rolled so they cut roof off cab truck runs and drives good as is roll a new can on it and have a sweet truck call or text 509-460-2053 best offer trade part trade only have till Thursday night to do something with it or ill part it out TEXT PLEASE and no calls after 10 pm
  10. Jamie Miles
    I saw an early 90's toyota pickup at a cruise in with a 5.0 in it. The trans tunnel was modified to clear the bellhousing so the motor could sit as far back as possible, and the core support was modified so the radiator could sit as far forward as possible.. It was still extremely tight up front. Personally I'd just sell the toy and find a cheap Ranger.
  11. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
  12. 70Maverick70
    70Maverick70 The faster the better!!
    Manitoba
    I have a 90 yota, and I myself have looked into it. There are kits online for putting in a chev 305 or 350, because they drop in fairly easy with little modifications. But I recall to make a 302 fit in you have to push back the fire wall quite abit for everything to fit in properly.
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    I've seen plenty of those swaps through the years.. and can't say that I know much about the actual logistics involved here.. but that makes no sense when you consider that the 302 is a smaller engine that the SBC. Especially considering that the Chevy has a rear-mount disty to worry about.
    If it can be made to eat the Chevy.. it should swallow the little Ford even easier. (y)
  14. injectedmav
    injectedmav Member
    Georgia
    Especially if you use the short timing cover and water pump accessory drives:yup:
  15. Bryant
    thats the trick right their. the traditional ford water pump and pulley locations make it longer than the chevy 350.
    going to the short explorer front accessory package really helps.
