99-04 suspension swap in progress
Discussion in 'Technical' started by LukeDuke, Aug 10, 2017.
  1. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    Hey guys been awhile since ive posted. Thought i would share my progress on my comet. I have done a lot of research and have not found anyone that has attempted this, but plenty of people said it wont work. Im nowhere near finished but it looks completely doable to me. I found this complete suspension on Craigslist for 100 and very adjustable coilovers on ebay for 350. I have a buddy helping me set it all up and weld it in. The only down side to all this is, this will increase the track width by 4 in. I can install foxbody arms and that will cut off approximately 2 in. So i may have to get high offset wheels and roll fenders but thats no big deal for me, im not looking for a stock look. Biggest motivation for me doing this is more room under the hood, and rack an pinion steering. 20170809_192315.jpg 20170810_115936.jpg 20170810_115901.jpg
    stumanchu likes this.
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Have you seen the AJE setup? It's very similar and uses Mustang parts.
  3. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    Yes i have seen it. But its 2k for the set up and i dont like the tube style a whole lot. most of the parts they claim are exclusive to aje they say other parts dont fit? I like the idea of being able to stop at any old parts store and get a ball joint or control arm bushing if i need one instead of trying to figure out what the right part is and wait 2 weeks for it to arrive. I plan to drive this car not let it sit in the garage like most people do and i dont think aje control arm bushings will put up with it from what i have seen
  4. greasemonkey
    Sedalia,MO
    If you use the mustang shock towers you can use mustang coil overs. And I honestly wonder if the fox arms would work. Youd be using the mustang spindles and brakes also.
  5. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    Yes i am using mustang coilovers that have more then 6 in. of adjustment.
    http://www.ebay.com/itm/122314057995
    They accepted my offer of $300 on this set of struts! they look fantastic, i just hope the proform the same lol.
    We are custom fabricating shock towers.
    Ive found a few people claiming they are running foxbody a-arms on their 99-04 mustangs so i think it should work but personally i have not tried yet. I think you have to put a 99-04 ball joint in the foxbody arms to get the knuckles to fit cause the struts set lower on the knuckles on newer mustangs.
  6. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    It was quite difficult getting everything perfectly centered and getting wheel base just right but we got it and tacked it in. And i got to test fit the ls! Now to move on to cutting and building 20170815_192506.jpg IMG_20170815_211636_011.jpg 20170815_195438.jpg 20170815_192548.jpg towers.
  7. greasemonkey
    Sedalia,MO
    Omg. Someone's confused! The suspension looks good.
    LukeDuke likes this.
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    This is definitely interesting to me. You got my attention.....keep it coming.
  9. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    Ok so the struts i got on ebay are junk they are a good 4 inchs shorter then factory struts so i am working on a return and getting upr coil over kit to fit factory struts
    Got some rust repair done and cut some of the tower off
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    Some? heheheheheheh.
  11. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    Finished some welding. Looks like i have a small rust hole in the floor haha 20170823_174023.jpg 20170823_182812.jpg 20170823_200932.jpg
  12. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    Got some foxbody a arms which narrowed the track width and started on shock towers. So glad i have help with this! I have adjusted these struts out to factory length struts but i only have an inch of thread or less before they fall apart. So im not sure if i will end up using them or not. 20170825_201611.jpg 20170829_195041.jpg 20170829_195046.jpg 20170829_203344.jpg 20170829_203351.jpg 20170825_201611.jpg 20170829_195041.jpg 20170829_195046.jpg 20170829_203344.jpg 20170829_203351.jpg 20170825_201611.jpg 20170829_195041.jpg 20170829_195046.jpg 20170829_203344.jpg 20170829_203351.jpg
  13. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Are you converting to 5 lug or staying with 4? You may have posted it but I didn't go back and review.
  14. Wizz
    Wizz Member
    Oakland,ca
    1977 maverick
    Awesome
  15. stumanchu
    stumanchu Stuart
    Portland, OR
    The front of this car looks like it will be quite strong when it is done. Fabbing shock towers is a bit beyond my welding abilities, but I imagine saving a chunk of change by not going mustang 2 will cost some time and fabbing....but when you are done you will have mustang 5 !
