A/C Compressor
Discussion in 'Technical' started by NewMaverickGuy, Jul 10, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    What wires feed power to the ac pump? What color? I wanna make sure it turns on before i go buying refrigerant
  2. Craig Selvey
    It is a single wire that comes out with the vacuum hoses thru the firewall.
    As long as that car has been sitting, you will need more than just freon.
  3. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    What all do i need?
  4. mojo
    You need to have it tested to make sure it will retain "leaks" refrigerant, hoses and o-rings will most likely need replacing, compressor may not be operational. Heat/AC box needs to be checked for cracks that will leak water in cabin if cracked or drain hose is not attacked to to drain nipple. Long story, short, liked Craig mention you will need more than refrig. if you want it to work w/o a lot of money & time spent as it suppose too.
    Krazy Comet likes this.
  5. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    The compressor doesnt come on when i turn the ac on. I have it plugged in and the fuse is good
  6. Krazy Comet
    To put it bluntly, your chances of winning Powerball are greater than a '70 A/C system not having leaks.
    jasonwthompson and mojo like this.
  7. 71gold
    I don't know if a 70 has a binary switch but if it does that is why it won't come on.
  8. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I just want to make the compressor work. I figured that would be a good starting point. The blower works also. Well, like a nearly 50 year old motor would be expected to work. As a side note, my windshield wipers even work. That impressed the heck outta me.
  9. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Have you identified the power lead going to the AC clutch? If so does it show voltage when you select AC? If it does and the compressor does not engage, you will probably need a coil and/or clutch. Even if it engages, the compressor may or may not be any good.
  10. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Well, as far as it possibly not being any good, thats what i'm aiming to find out. I haven't tested the wire going to it. Ill try that tomorrow and see if it helps. Is the power for the a/c clutch on with the key on? If so, wouldn't I be able to hear it engage when i flip the switch over to a/c?
  11. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    It kind of reminds me of the pto clutch in my old craftsman 2. It also uses an electromagnet.
  12. 71gold
    just stick 12V to the clutch wire, that should let you know if the clutch works...:huh:
    if you go through the switch the binary switch will need to be satisfied for it to work.
  13. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    how exactly can i get to the binary switch to inspect it?
  14. Krazy Comet
    Switch is on plenum but if there isn't vacuum connected to the switch actuator, it'll never turn on the compressor. After you connect vac you'll probably need to find a dozen leaks.
  15. rthomas771
    Here is the switch that controls the compressor. The 70-72 switch (left) is replaceable...the 73-77 (right) is made onto the vacuum switch.
