A/C Problem
Discussion in 'Technical' started by texasjack, Jun 4, 2009.
  1. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    I pulled down the A/C on my 75 the other day and the low side went to 30 real quick. I opened the high side and it would only pull 15 after 30 minutes.
    I figure I have a hi side leak but where?
    Texasjack
  2. Bryant
    when ever i try to find a ac leak, i pressurise the system. i made a connector that hooks shop air to the ac lines. then take a squirt bottle full of soapy water (carwash soap works really well because its sudys) and spray down the whole system and look for bubbles.
  3. Dave B
    You can't use a vacuum to find a leak, Like Bryant says, you need to pressurize the system.
