a frame assenbly???
Discussion in 'Technical' started by mav76, Oct 18, 2004.
  1. mav76
    mav76 New Member
    edmonson county, ky
    1976 Mav. 4- door, 250-I6
    the other day i went to get my front end aligned on my 76, 250 i6, mav. and it turns out that i need a new a frame i think or a frame bushings, any way i looked around the internet but i can't find anything does any1 know where i can get one.....
  2. Michael Kilgore
    Michael Kilgore Member
    Yo, Mav76,
    What you may need is "A"-frame bushings. They're inexpensive and relatively easy to replace. Firsy spend $12-15 for a proper manual, readily available at most any auto supply store or book store. You'll then have a good referance for all future mechanical projects.These upper control arms have eccentrics which, when turned change the alignment settings i.ei caster and camber. If the bushings are too worn, the settings will not remain constant.
  3. mav76
    mav76 New Member
    edmonson county, ky
    thanks for the info
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    The eccentric is in the lower control arm on these cars, not the upper.
    This is used to change camber. The caster is changed by adjusting the strut rod length.
  5. 71gold
    mav76,
    if you put the upper a frame bushings in, it would be a good time to put in the 90 degree zert fittings. also be very very careful removing the springs. i have had good luck with the "inside" spring compressor...frank...
    p.s. check the upper ball joint while you have it out. the lower control arm has the ball joint as an assy. the spring perches are there too so they can be replaced at the same time. g/l and "safty first".
  6. mav76
    mav76 New Member
    edmonson county, ky
    yeah i need both upper and lower ball joints, new front shocks, the a frame bushings, the rack and pinions, and i some kinda spring seat i'm going to try to buy them all then one weekend put them all on, right now the inside of my front tires get worn out till the wires are showing in about a month
  7. Craig Selvey
    You need to buy an entire kit from Canadian Mustangs. Do a search...several post about this subject.
  8. Snazzman
    Snazzman She's a beautie....
    '73 mav 4Dr
    Yuppers
    Yo Mav76, we're in the same boat, I'll let you paddel though! hehehe
  9. mav76
    mav76 New Member
    edmonson county, ky
    i'm at the can. mustang site right now, is there a year mustang front end i should look for or what??
  10. Craig Selvey
    1972 will work. Get the complete kit with the pre-assembled upper and lower A-arms.....makes it real easy.
