AC evaporator thermostat
Discussion in 'Parts Interchange' started by mojo, Sep 2, 2016.
  1. mojo
    I recently had my AC serviced after installing a new compressor and dryer, found out I need to replace my evap. thermostat. Anyone know where I can get one? Will one from a Stang work? I have the switch bypassed temporarily -- but want to get it right. Don't want compressor working all the time!
  2. Craig Selvey
    I see them on eBay all the time.
  3. mojo
    I had not thought about Ebay! I did see some on CJ Pony Stang site. I plan on removing the one on the car to see what it looks like -- don't want to order the wrong part. I know little about AC systems, but, learning a lot from installing 2 compressors and dryers, refurbshing heater/ac box, installing compressor overide sw and such. Anyway, thanks for the tip. I assume a lot of those switches are similiar in Fords of that era. Do you know if I will need to remove heater box to install the switch and/or sensor in the evaporator?
  4. Craig Selvey
    There is a probe that goes into the evaporator...so you may need to disassemble part of the box.
  5. mojo
    That's what I was hoping not to do -- once was enough. I will leave it as is for now, since it's working better than it has since I got the car. Drove it today, had big smile on my face. It was not that hot today, but, humidity creeping up.
    Anyway, I will recieve the most use on highway trips. Once fall season is upon us, I will do whatever is needed to fix the evaporator sensor.
  6. 71Mavrk
    71Mavrk Member
    Nevada
    No need to remove the box. Just have to be careful sliding the probe into the hole.
    Micah
  7. mojo
    Yea! I brought up some pic's of the box when I had it out for refurbish in 2010. It was/is very helpful in determining whether that box need removal or disassembling -- I see it bolts to the rear of the case near driveshaft hump.
    Keeping pic's of all the major things I have done comes in handy in a case like this.
    l am waiting till weather cools down some to replace the switch -- using it non-cyclying mode till then, just glad to have it working.
    Thanks for the reply -- Micah!
  8. Craig Selvey
  9. mojo
    Craig Selvey likes this.
