Alright, Im full of questions today. My maverick has factory A/C. My dash vents just dont seem to blow hard at all. Is this notorious for mavericks or do you think something is wrong with mine. I can barely feel the air blowing thru my center vents. So anyway. What should I expect. Thanks Steve
steve, check the duct work under the dash.... also there are vac. lines that open and close the vents, check them and make sure they are hooked up and not busted ..frank....
The defalt position for factory air cars is the defroster. If most of your airflow is comming out of them, your not getting enough if any vacuum, or your vacuum switch is probably broken. Next step would be the vacuum motors that open the various doors to direct the airflow.
They blow out the defrost if I hit more than 3/4 throttle, When on the high setting it doesnt feel like thats enough. My A/C has been convereted to 134 so thats bad enough .
