Accelerator pump
Discussion in 'Technical' started by TM74, Feb 22, 2017.
  1. TM74
    TM74 Member
    Buffalo, NY
    1975 Grabber
    Never saw one like the old one, how do you remove it? It seems attached? The new one doesn't have the long shaft on it, is there a different one?
    Thanks.
    Todd
  2. Krazy Comet
    Old diagram will pull off, it's just stuck... There should be a small shaft in kit to use as extension, carbs from '64-ish to early '70s didn't use the extended shaft...
    So why are you replacing pump? Usual reason is leakage...
  3. TM74
    TM74 Member
    Buffalo, NY
    1975 Grabber
    Thanks. It dies when you put it in gear until it's at full operating temperature. Figured I'd start there since it's been sitting for the majority of the last 25 years.
  4. Krazy Comet
    The accelerator pump doesn't do anything till the throttle is opened, not likely going to help your problem...
    TM74 likes this.
  5. TM74
    TM74 Member
    Buffalo, NY
    1975 Grabber
    Thanks, any idea what it could be?
  6. Hotrock
    Munroe Falls, Ohio
    Do you know how to adjust a carburetor?
  7. TM74
    TM74 Member
    Buffalo, NY
    1975 Grabber
    Using the idle mixture screws and the fast idle screw, yes..
  8. Krazy Comet
    If it doesn't have a vacuum leak and adjusting idle mixture doesn't help, the idle passages in bottom of carb may be restricted... Way back when, I had more problems with power the valve in these carbs than anything else...
    Vacuum leaks can be anything from a cracked hose to a stuck PCV valve or leaking EGR valve...
    TM74 likes this.
  9. racing ranger
    racing ranger Member
    Iowa
    72 Comet GT Boss Powered, 83 Ranger S/G, 94 F250 Styleside 4x4, 2007 Ford Focus SES
    Choke problems and maybe fast idle cam or both.
    mojo and TM74 like this.
  10. Craig Selvey
    Time for a complete carb rebuild
    Krazy Comet likes this.
