Adaptor Plate????
Discussion in 'General Maverick/Comet' started by 71351wmav, Mar 4, 2005.
  1. 71351wmav
    71351wmav Member
    Hermiston, Oregon
    1971 maverick
    [​IMG]I HAVE THIS INTAKE AND A 600CFM EDELBROCK CARB ON IT AND IT SEEMS TO HAVE A VACUUM LEAK AT THE BASE EVERYTHING IS NEW, AM I SUPPOSED TO HAVE ONE OF THOSE THIN ADAPTOR PLATES FOR A SPREADBORE-SQUAREBORE INTAKES?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If the carb has equal bores everything should be fine. Get a steel straight edge and make sure the mounting surface of the manifold is flat. Check the carb base plate also.
    If it is slightly off try using 2 gaskets.
