adding heads to my car
Discussion in 'Technical' started by Jazz, May 1, 2007.
  1. Jazz
    Jazz New Member
    Winnipeg, Manitoba, Canada
    1973 mercury comet gt
    Hey everyone, i just pulled my comet out of storage for the winter last weekend, and i realised my head gasket is leaking, since i am taking the heads out to replace the gaskets i am going to change the heads as well, i was wondering what would be my best bet for heads. my comet has a 302, with a few mods to it, (intake, card, cam, pistons, stall) anyway any advice would be greatly appreciated... thx
  2. stmanser
    Davenport, Iowa
    depends on how much you want to spend..
    you can have your heads reworked for the cheapest way
    or you can go and buy some aluminum heads
    the question is.. what do you want your car to do? do you want power? are you going to race it?
    every day driver?
  3. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    The other option that Simon didn't add was the later model E7 heads. Those are plentiful in wrecking yards and on the internet and flow better than the older heads. Kind of a middle ground between aluminum and stock.
  4. 19BlacK77
    19BlacK77 Member
    I would go with a set of WORLD cast iron roush 200 heads. They are cheap and should bump up your performance quite a bit. Here are the specs on them.
    200cc intake
    64cc combustion chambers
    2.02/1.600" valves
    1.250" springs (100# seat/.560" max lift)
    3/8" studs
    The best part is that they are only $469.99 in jegs.
  5. 71gold
    Simon...Simon...Simon...:slap:
  6. stmanser
    Davenport, Iowa
    is that for the pair... or each?
  7. 19BlacK77
    19BlacK77 Member
    The jegs book says its for the pair. Just checked the web site and it said that was each. It must be a misprint in the book. Someone should make them own up to the price. :)
  8. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    E7s aren't worth the effort. If you can find some GT40 heads from an Explorer or something, that would be an improvement. You didn't state cam profile, whether you were running exhaust manifolds or headers, and other stuff, which helps people give you advice. You can also find used sets of Edelbrock Performers etc on ebay.
  9. scooper77515
    Go GT40 and NOT GT40P
  10. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Those are nice heads, but the 64cc chambers would drop his compression ratio...
  11. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    I don't see much wrong with the E7's, considering all 70's castings going to be worn out and need lots of money to make good again. I have a set on mine, I lightly ported the exhaust, and put them on a stock 86 Bird short block, so far runs low 9's (1/8) stock converter, 3.00 gears, has more in it, chasing some tuning problems. Will be easy 8's when traction/tune comes together.
  12. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    How much because the GT40 are in the range of 62cc or 64cc I think. So it would also drop compression. Would the smaller runners & valves on the GT40's give better throttle response for driving on the street?
  13. scooper77515
    Much better throttle response. And I think they are 58cc's if I am not mistaken.
  14. Max Power
    St. Paul, MN
    Many 70s 302 heads were 67-68CC, so your drop in compression would be relative.
    I never recommend heads with 2.02 heads unless you are building the whole motor and can source pistons that will work with them.
  15. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    They can be milled to 58cc nice heads for the money. I'm to lazy to read what his current combo is but a set wolrd jrs might be better.......
