Adjusting a rich carb
Discussion in 'Technical' started by wulfhinzdenzin, Jun 2, 2007.
  1. wulfhinzdenzin
    wulfhinzdenzin Member
    Andrews AFB. MD
    72 maverick
    I have a problem with my car running rich that it wants to flood itseslf out. I am using that stock 1 barrel carter car but :hmmm: i dont know how to adjust the richness or where the adjustment screw is located :cry: .
  2. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Float
    If it's running that rich it is likely the float level adjustment. Float may be waterlogged and holding the needle and seat open.
    It will have an idle curcuit screw that adjusts the richness at idle, but it will have jets or passages inside the carb that regulates the main curcuit richness.
  3. stmanser
    Davenport, Iowa
    buy a 1 bbl rebuild kit. the directions will tell you how to fix it
  4. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    (y)
  5. wulfhinzdenzin
    Andrews AFB. MD
    72 maverick
    thanks for the advice i will have to wait until it stops raining and then i will try to get a better look at the carb. Thanks again
